I tried their Honda Acura spec Power Steering fluid, which was labeled Full Synthetic.
Seemed to work fine.
Why don’t you call or email THEM and ask your questions? Seems to be a more productive way of going about getting the answers you’re seeking.Oh but there is more.
So, how does outperforms. Vw507.00 when VW doesn’t test 5W40? And, what is Skoda specification? That doesn’t even exist.
I not paid to do that. I am telling you that a. they don’t know what they doing b. They are trying to scam customers.Why don’t you call or email THEM and ask your questions? Seems to be a more productive way of going about getting the answers you’re seeking.
Oh....this being based on answers you didn’t get cuz you’re not paid to? Sound logical analysis.I not paid to do that. I am telling you that a. they don’t know what they doing b. They are trying to scam customers.
which answers your question whether someone is going to give it a try to this oil.
No, I am not going to email them. Not my job.Oh....this being based on answers you didn’t get cuz you’re not paid to? Sound logical analysis.
What do you look at on the VOA or used oil analysis to tell if it worked as advertised? For example, let's say I want to know how well it meets the requirements of Volkswagen 504 00 approval, as advertised that it does. What parameters of the used oil analysis/VOA would I look at?My vehicles run on lies... the recommendations from automakers. Seems to be common among all the 'boutique' brands and automakers.. Big deal.
At the price mentioned, not a bad buy for those of us that boycott malwart.
So, if you use it, post some VOA/used oil analysis to see if it works as advertised.
If I see a bottle claiming 90% less !!!80% less cam wear!!!!!
Why would anybody use anything else?
"Oil falling out of spec" is your entire criteria? What spec? Grade?Look for? the engine isn't grinding apart or oil failing out of spec
The manufacturer approval isn't and end all. I use plenty of oils, intervals, filters, and grades that aren't manufacturer approved. I've seen many mechanical failures with so-called superior advanced OE recommended lubricants.
Maybe if the VW/Audi/BMW/MB specs were so great, they wouldn't have non-stop engine problems. Stick with the OE approval if your live in fear of anything not approved. I don't live in fear of monsters in the closet, boogiemen under the bed, scamdemics, or OE "recommendations".
Other oils that weren't approved that I've used..... MPT, Amsoil, Redline, Torco, Neo, or how soon many forget RLI in a BMW. How did RLI compare to the 'approved oil'? or non-approved Rotella T6 in the VW TDI?
Be afraid... be very afraid... oh so afraid
Thanks!! Impressive amount of anti-wear metals. Just wonder how it meets GM Dexos1 Gen2 specs with so much ZDDP? Other oils I have seen with the GM licensing increased the Moly to compensate for lower ZDDP.I did. I posted them in the VOA section
We need more power, Scotty! Auxiliary power to the active, regenerative plating!I had never heard of Triax until now in spite of other BITOG threads on this oil.
Question: can you have TOO much boron and moly in an engine oil?
And it’s sold on Amazon for $27.50 per gallon jug. What raises an eyebrow with me is this claim:
Note- bold highlighting is mine
- “Friction modified; active plating on engine parts; extremely resilient, regenerative layering of Moly & Boron on metals......”
For Star Trek fans, that sounds like Borg technology.
I’d like to see the VOA on this oil when it comes back. And hopefully a used oil analysis, too.
Agreed, I have used Redline in the past, only to have a used oil analysis condemn it after 4000 miles. Engine condition very important to longer OCIs. I used Herguth Lab (now part of SGS) in Vallejo, CA. I presume it would not be a good idea to use this oil in a catalyst equipped vehicle? Given the high amount of ZDDP?Concerning a failure point of an oil.... ANYTHING that changes excessively when compared to any other 'licensed' products. Unlike the fools that only believe in TBN, there are many other overlooked failure points. Might need a better lab than the non ISO certified $25 special that many rely on. The most overused quote here in the used oil analysis section... "TBN looks good so use the oil longer"
I read an article where additional ZDDP added to a low quality oil improved the AW of the oil, but adding ZDDP to a high quality oil actually LOWERED the AW effectiveness. I'm wondering if this is excessive? I would assume (and hope) not, given it was engineered into this product. The article was describing using aftermarket ZDDP additive.If the VOA is accurate, then consider it a stout additive package and one only can see if it works well in an engine.
I'm not looking for Euro recommendations, but I would think the 10cst would hold up due to the fact it is a PAO and shear stable.Since this oil has a 10cst VOA, it does not smell like a high HTHS euro oil. So, don't whine about their Euro recommendations since this is their so-called US/Asian 5w30.
Actually, the Moly additive does just that, it attaches to metal surfaces and sacrifices itself, if you will, to protect the wear surfaces. This of course depletes the additive.We need more power, Scotty! Auxiliary power to the active, regenerative plating!
Remember those as well. My hearing is down because of them...The only Triax I've used was Jensen 6 x 9's
$104 for a 5gal bucket on eBay@ $27.50 I'd just use something mainstream.
