Originally posted by Motorbike:
Originally posted by Patman:
This is my biggest beef on this site with the thick oil crowd. No used oil analysis from them! But yet they just seem to know for fact that their thick oils are giving them lower engine wear.
Some ! also don't even read! these posts !thouroly !before replying !to them either !as you might have! witnessed !.
Crossbow has pointed out the use of light oils in Asia . TC has provided many links . I have too along with countering the why does Ford not use thin oils in Europe with links showing the many Ford and Jaguar specific oils now available . I've also pointed to 4 engine oil analysis's of the same engine using the same brand 15w40 in Florida where it's warm most all the time and when the engine was switched to PCMO 30wts the wear metals lowered in the last two used oil analysis .
I have also posted the Mobil Au site and their recommendations for new Toyota cars which is 30wt not 50wt . The ELF site , AGIP , Aral and others are highly touting their new light weight oils with long drain benefits and better fuel efficiency . It's happening all over the world not just in the U.S.A .
Whats that river in Egypt named ?
Motorbike:
I went to the Esso Mobil Australia site:
http://www.mobil.com.au
And followed the links for recommended oils for application.
Esso Mobil in Australia does not appear to sell any xW-20 oils at all. If you can provide more information on this, please let me know.
I first checked Ford and their current model year 5.0 V8: Mobil 1 10w30
I then checked a current 2.0 litre DOHC, like current Zetec-series motors: Mobil 1 5W-50
I then checked on Ford's economy car, the Ka 1.3 litre: Mobil 1 0W-40
Ok, next I checked Honda, as they "require" a 5W-20 here in North America.
The current Honda Civic: Mobil 1 10w30
Out of curiousity, I then checked for a 1992 Honda Prelude, as I used to own such a car. I always ran Delvac 1 though Honda recommended a 5w30. Once on a hot summer road trip I ran Mobil 1 15W-50, which I suppose would be VERY BAD according to your logic.
1992 Honda Prelude SI 2.3 litre DOHC: Mobil 1 5W-50. So I should have used Mobil 1 15W-50 in summer in my Prelude all along.
What a crock of s***.
I do know that Toyota Australia has general recommendations for a 20W-50, which I have posted before. Some of their VVT-i motors require a synthetic-blend 10w30, but it does appear you can also use the 20W-50 as a substitute in Oz.
http://www.toyota.com.au
I looked up the current Toyota Echo Hatchback in either 1.3 litre or 1.5 litre motor: Mobil 1 5W-50
I then looked up the Toyota Corolla 1.8 litre: Mobil 1 5W-50
Hmmm. How about the Camry 2.2 litre? Mobil 1 5W-50
I also checked the BP Lubricants site and most current model Fords, Honda's, and Toyota's have a recommendation of either 10w30 or a special high-performance synthetic "Visco 7000" 0W-40.
I have also posted the lubricant notes from BP Lubricants and they have a very wide range of viscosity for those makes, depending on temp, up to 20W-50.
I have vacationed in Europe and the price of fuel is frightening compared to North America. You would think the Europeans would all recommend a 5W-20 or an SAE 10W for maximum theoretical "gain" in fuel economy.
So when my 2004 Toyota Echo Hatchback 1.5 litre arrives, I will "compromise" and run the following oils:
Mobil Delvac 1 5W-40 summer
Mobil 1 0w30 winter.
After I showed the local Toyota Service Manager the above links and recommendations, he suddenly shut up about running a 5w30 year round and mumbled "That's what we're forced to do."
Jerry
Jerry
