Well, it is too early to tell, but as others have pointed out, I am unaware of any Euro mfr who has endorsed this oil for high performance use. Let's see what happens in 5 years as cars that came with the low-vis oils start to run up some miles. Personally, I did not recommend nor use Ford's recommendation of 5w20 in my 2003 SVT Cobra. I used 30w, in either 0,5 or 10w winter ratings.
I do know that Ford went to it for the "green effect" of reducing emissions and increasing MPG. The oil will certainly get them through the warranty period. But I also found this:
http://www.epa.gov/otaq/cert/dearmfr/ccd0112.pdf
This pressures Ford to not recommend a synoil in 5w20. Why? They say why - to keep the price low, which they hope will motivate people to use it. Unfortunately, when one calls SVT, they say stuff like "the engine was not designed for synoil", giving the uninformed caller the impression that it is somehow "bad" to use synoils. The EPA letter shows why SVT makes the recommendation. The irony as I see it is that with a 5w30 synoil, one could go to 3x the change interval, reducing the effects of waste oil dumping, emissions, and scoring equal or better fuel economy, while still providing a higher level of protection in extreme conditions or loads. This is unfortunate.
Personally, I would not want to be the guinea pig if it turns out that low vis oils do not perform as well as their "thicker" colleagues over the log haul.
