Originally Posted By: kaboom10
Wish I had known you when we got in a 4.6L prototype ford modular. I used to work for McCord gasket. We reused the head bolts that came with the engine. Our method was to put an alignment mark on the head/bolt and loosen the bolt. Then we would tighten the bolt back to the alignment mark and see what the readout was on the torque wrench. Still not a fan of TTY so for my modular engine I bought studs for all of the TTY.
I've heard a slight variant of that, for thread lube fans. Torque it dry, note the position at torque (I suppose counting turns if necessary and then measuring the angle of rotation), take it off again, lube it, and put it back in the same angular position.
Only tried that once with head bolts, on GF's scooter, but I dont THINK it had TTY bolts.
Still don't like dry threads though, even in that temporary situation. Just doesn't feel right.
