Almost always when working on vehicles you need to clean the threads of an old fastener, especially if you're re-applying loctite.
Using a bench grinder with a steel wire wheel works real good but the steel very quickly strips off the protective zinc or nickle plating on the fastener - the bolt looks clean and nice but not for long! Without the plating the raw steel will corrode super quickly, so you've actually done more harm than good.
Any advice on how to clean fasteners without damaging the protective coating? I've been using a brass wire brush, but not sure if that's ideal. Brass is technically a mix of zinc and copper, and copper is super soft, so I'm assuming it would be softer vs the electroplated zinc or nickle coating and won't damage it while still removing dried old loctite, rust, etc?
I know you can get a full on zinc plating set up to refresh the protective coating and there are youtube vids showing how to do that, but there is a ton of prep involved and would be far far too time consuming for general vehicle work! I'm not restoring an antique to shiny ocd perfection, I just want to avoid doing damage to high quality OEM plated fasteners while doing general work.
