Henry Homesteader 9mm Review
USA
- I Recently decided I needed a rifle that bridged the gap between .22LR and 7.62x39. As far as ammo expense and recoil. I also wasn't interested in investing on mags for another platform. The homesteader 9mm fit the bill. I chose the model with the Glock magwell adapter since it's my main pistol platform. They have decreased in price since first released. Picked this one up for $799 plus tax.
Ergonomics/ Handling
- Overall the rifle is well balanced. The rear and froward grips are quite comfortable. The grip texture is not your typical checkering. Seems to be a type of gritty lasered texture. It's a good balance between providing a good grip but not excessively aggressive. The butt pad is very comfortable. It's a very firm rubber material with good grip. Feels well made and shouldn't deteriorate anytime soon. I personally prefer metal butt plates like some of Henry's other offerings. However, the rubber pad does a great job absorbing recoil. The Glock magwell does have the mag release button on the left side vs the underside with henry's in-house mags which is a positive in my opinion. The stock comb is well placed and provides a good line of sight with the apertures. Charging Handle is ambidextrous and very easy to swap around. I'm a righty and found having the mag release and charging handle on the left side very comfortable at the range.
Range Time/ Reliability
- Rifle was cleaned and lubed before first use. My main purpose on this first session was to ensure function with a variety of Glock Gen 5 OEM 10-33rd and Magpul 15-27rd aftermarket mags. Rifle functions flawlessly with all Glock and Magpul mags. I only had access to a 50yd bay this time and accuracy was very good. I was consistently hitting a small 5 inch reactive steel target off a cheap foam rest . I wasn't really measuring groups but eye balling them I'm confident with proper rifle rest and good ammo 1-3 moa is achievable at 100 yards. Rifle was fed roughly 500rds such a ball ammo like Fiochi 115gr, Magtec 115gr, and Belom 124gr Nato spec. Also shot several defensive loads such as Federal Punch 124gr, Hornady FTX 115gr/ American Gunner 124gr XTP/ Subsonic 147GR XTP, and Sig V-Crown 115gr. All loads above cycled nicely and locked back the bolt every time on an empty mag. Seemed like Nato Spec 124gr shot POA/ POI. 115gr range ammo seemed to shoot couple inches low at 50yd. I sighted the rifle with a mix of ball ammo so obviously you can sight yours in to your specific brand. It's just something I noticed shooting a variety of ammo. 124r was the most accurate as far as POA/ POI. Trigger pull felt like 6lbs and slight creep out of the box. After 500rd break in and lubed it's very nice and crisp at roughly 4-4.5 lbs with no creep. Trigger reset and tang safety is very audible/ tactile which is a big positive. Recoil was very soft and pleasant. The action mass cycling is very smooth and consistent.
Maintenance/ Craftsmanship
- After roughly 500rds rifle was cleaned and inspected. Very little wear on the parts. And to my surprise almost no wear on the anodizing inside the receiver aside from the receiver bolt rails which had very minimal finish wear. The Bolt seemed to have some type of TiN coating which makes it smooth/ slick. It was relatively easy to clean. However, the bolt face did require a little effort since the blow back design sort of cooks the carbon on the metal surface similar to an AR bolt stem. Overall disassembly isn't to bad considering its just 3 pins and a Allen screw for the handguard. The pins can be very snug at first but get better after being removed a couple of times.
- Fit and Finish seems good. Parts all have minimal wear. The recoil spring/ front bolt weight design is quite clever. There's several similarities to m1 carbine/ Garand/ AK type requirements for grease lubrication due to large parts sliding and tolerances. Although the owner manuals calls for gun oil. I initially used gun oil but switched to light film of GP synthetic grease.
- The aperture sights are very nicely done. They are of Xs brand. Adjusting them is pretty straight froward with a small flat head screw driver. Since it's drilled and tapped for weaver 63b rails I may mount a red dot in the near future. Ranger Point makes a rail specifically for the homesteader that still allows you to use your stock aperture sights with the rail installed.
Final Thoughts
- I'm very pleased with my purchase. Rifle is built like a tank. Craftsmanship is a 9 out of 10 and it's made in the USA. There's many people comparing this rifle to AR9's, Ruger PC carbine etc. However, this rifle it what it is. If your looking for a quality built rifle that can become heirloom this is it. I don't feel like Henry was aiming for either tactical or Hunting markets. In my opinion they just wanted to offer a solid 9mm carbine alterative that great for anything the user wishes. Whether that's plinking, hunting, competing or all of the above. You either like it or you hate it. I'm sure the aftermarket will eventually catch up and provide new furniture like aluminum rails/ stocks etc. Like their other products knowing their industry leading customer service really made me confident on my purchase. Just having the confidence if any issue arises Henry has my back to make it right. My only cons this rifle is the lack of weaver rail out of the box and handguard attachment. The front front handguard uses a angled Allen screw which provides clearance from the barrel to use a plain Allen key. After 500 rounds it did slightly loosen and gave a slight play to the wood. Even though it's solid quality walnut. I don't like the idea of cranking down the screw excessively every time I clean it. I wish they designed with some sort of ratcheting end cap/ bolt similar like a shot gun tube or used a barrel band. I applied more force this time and will keep an eye on it. Maybe it just needs a good tightening and will not damage the handguard. If you've been thinking about picking one up go ahead. It will not disappoint you. Thanks for reading my review and hoped you enjoyed it.
Cloud Wood Air gun Outdoor recreation Sky
no good idea doesn't get duplicated...whatever happened to the Marlin Camp Carbine?
I have one. Camp 9. They don’t feed near as well as the Camp 45. Both are fine but the 9 took the SW 59 series handgun magazines and could be problematic.
I got both for a song. The 9 was in a smallish parts box. Someone had painted it and worse. I rebuilt it and even had it professionally revalued.
My Camp 45 was NOS. Sweet checkered stock. By the time the 240gr hits the target beyond fiddy yards you could make a grilled cheese sammich.
I got both for a song. The 9 was in a smallish parts box. Someone had painted it and worse. I rebuilt it and even had it professionally revalued. BLUED
I typed RE-BLUED (phone auto correct)
Anyway. Nice review. Kinda want one. Not sure if legal now in WA state.
Thank you for the review. Nice carbine. Should be lots of fun. Cheap to feed.
Interesting that it can be equipped with Henry, or Glock, or S&W magazines. Glock makes sense to me , personally, since I own a couple of 9mm Glocks. I’ve had excellent results with the Magpul Glock magazines as well. Not one problem in over 1,000 rounds. They’re a great, and inexpensive, choice.
I really like the traditional wood and steel look. Henry builds a quality product. The fore grip on yours appears to have some great figure in the wood. Really nice looking.
One note on pistol caliber carbines - the recoil is more than I expected. The extra barrel length allows the bullet to reach greater velocity, so, the recoil is higher. First time I fired my Ruger model 44 (a .44 magnum carbine) I was shocked by the recoil. Kicked harder than a Garand. A lightweight carbine, coupled with a powerful cartridge, added up to significantly more than I expected.
So, when I saw the rubber butt pad on your carbine, I smiled. Sure wish my Ruger had one!
Interestingly the S&W magwell is also compatible with Sig P320 magazines. This rifle did recoil more than I thought it would for a little 9mm. Although it’s very smooth and manageable. I think the rubber butt pad and the semi auto system help. I’d love to see this rifle in 10mm. Who knows maybe next year Henry surprise us with a semi auto rimfire rifle.
Interestingly the S&W magwell is also compatible with Sig P320 magazines. This rifle did recoil more than I thought it would for a little 9mm. Although it’s very smooth and manageable. I think the rubber butt pad and the semi auto system help. I’d love to see this rifle in 10mm. Who knows maybe next year Henry surprises us with a semi auto rimfire rifle.
I’d be all over a 10mm! 😎
That would be an interesting gun to try to suppress assuming the goal was subsonic. Barrel length makes a huge difference in 9mm. I load my own but I had loaded some 124Gr HP 9mm that was subsonic out of my 4" pistol but was 125FPS faster out of a 10" 9mm barrel. Had to switch to 147gr projos to stay subsonic in all the 9mm stuff I have, but I've never tried the 147s out of a 16" barrel.
This looks like a great option to have diversity in your shooting platform.
For example, if you are cut off from ammo supplies (post-apoc or draconian laws or whatever) and you need to conserve your rifle ammo and want to squeeze the most out of your stash of pistol ammo.
HiPoint makes a carbine in 10mm.
https://www.hi-pointfirearms.com/hi-point-carbines/hi-point-10mm-carbine.php
I have the .40S&W version and it has been very reliable and easy to clean and lube.
I had access to a 9x19 and it ran pretty true.
The problem with most 10mm now is that it's loaded more like a .40+p at best, or it's 2$ a round.
I want a 10mm, but I know that I'll also have to get into loading my own if I do. If I wanted a .40, I'd buy a .40..... thanks ammo manufacturers!
My wife got me the homesteader for Christmas. I love the idea of 2 guns 1 ammo, kinda like the old cowboys with a revolver and rifle with 1 cartridge type. The rifle is perfect for scabbard carry on a trail ride, either on horseback or ATV, and as I am a SIG guy it's perfect. I have a side arm and a long gun with 1 type of mag and ammo.
Final Thoughts
Henry Goldenboy .22lr level action for the win. Great 👍 writeup and articulated. Thanks for sharing.
buy a 10 and change barrel like us Glock boys 👦 do lol and shoot the 40sw. I think it would be fun in 9mm
....... I’ve had excellent results with the Magpul Glock magazines as well. Not one problem in over 1,000 rounds. They’re a great, and inexpensive, choice......
I've been on the fence about trying Magpul Glock magazines for years.... Not wanting to deviate from the OEM Glock mags, of which I have several.
If you have run them over 1,000 rounds without an issue, I'm going to go ahead and give a few of them a try.
In addition to being inexpensive and reliable, they are also much easier to disassemble and clean. Not that a polymer mag needs a bunch of cleaning, but I do like to wipe down the follower and inside the body with a cotton cloth to remove the residue.
