3URFE tune up... found wrong plugs
burbguy82
$100 site donor 2024
NC, USA
So the other day, I went into town, and all of a sudden, I felt a misfire, all the warning light come on, etc. I limp home as i did not have my scanner with me, and it said misfire cylinder 3 P0303 if i remember right. Anyway, swapping #3 with #1 and the misfire moved to #1=bad coil.
So I ordered the proper Denso coils ( DENSO 6731309) for this engine, and 8 new plugs, (DENSO SK20HR11). To do a total repair, as the jackleg i bought it from had someone replace the coils with some aftermarket 1AAuto junk. 20k miles ago.
For a coil and plug job, this engine is pretty easy, not high creeper needed really. You need every extension for 3 to 12, a plug socket, and a 10 and 12mm socket.
In installing the new plugs, they felt a bit tight as they went down the threads.......squeaking and so on, everything to dont want to hear. I examined the plugs and found this:
Really, if you think on it for a moment, the spark has not really even been in the combustion chamber, it has been in the hole, so there was a good amount of nastiness in the threads. Luckily, I had a long cylindrical brush I have to AK47 gas tube cleaning, that work pretty good. In the picture you can see the discoloration of the new plug on the threads......that is how far up they were in comparison to where they are supposed to be. Surprised it ran at all.
Immedediate difference in startup and acceleration with the new stuff. Big difference. I typically do not use anti seize as it messes with the torque spec, but I did lightly coat two plugs which felt a bit tight.
It ran OK, for what I understood. Looking forward to see if there is any MPG gain.
I think i am lucky that this did not cause a much greater problem with the threads.
It’s the Toyota DOHC V-8.
Just did the plugs on mine. Bought them at the Toyota dealer. I no longer trust many of the aftermarket suppliers.
Vickie at the parts counter got me a brand new box, not just eight individual plugs in their boxes, but the larger box, untouched.
A level of service that you will not find at any online supplier. Yep, might’ve paid a bit more, but I know the plugs were perfect.
By the way, here are those plugs. When you look at the electrodes, and if you put a feeler gauge on them, they are indistinguishable from new. At 80,000 miles, the original Toyota plugs looked great.
I would go OEM, bought from Toyota, just to know you’re getting a good plug, and since you’re gonna get 100,000 miles out of it, the extra cost is both tiny over that life and absolutely worth it.
Yikes! I bet you'll see some more power and MPG out of that.
I almost did the opposite with my 4 wheeler. I ordered a Champion plug for it and thankfully compared them. The champion plug was SIGNIFICANTLY longer and would have probably hit the piston.
Trust me, I was second guessing my spark plug purchase for about an hour. Again, I am surprised the thing ran. I have nothing to based it off of, but the start up sound is more powerful, and the power level is up for sure. We will see about mpg this weekend, as I cant leave the house today.
Thankfully most plug threads of a given diameter are the same pitch or they would have tried to cram in the wrong thread pitch entirely!
Just stay on the impact trigger, Cletus!!
