Went to get oil change and transmission fluid was drained.
Hello. I’m new to this group. I have a 2018 4 runner. I took my vehicle to get the oil changed a quick oil change place and they mistakenly drained my...
www.4runners.com
Smart moveThis is a common issue with Tacomas and 4Runners. Numerous reports of it happening on tacomaworld.
While I do all my own oil changes, I still worry about some weird series of events where I have no choice but to leave the truck in some shop and they end up draining the trans instead of the motor. I actually wrote the word "TRANS" on the trans drain plug in permanent marker and then wrapped the head of the bolt with a zip tie so that it looks less like a bolt to someone not familiar.
that is a great idea!! I'm going to do this too!This is a common issue with Tacomas and 4Runners. Numerous reports of it happening on tacomaworld.
We used a VIOC once. I was on a week long business trip and headed on vacation the next day. So had the boss take her SUV to the VOIC for an OC. They cross threaded the drain plug in the process. I found the plug weeping when I got home. What a PITA.Got to keep that in mind next time I drive past a Valvoline instant oil change shop.
Honda did this on my 2019 CR-V. It has oil on the oil pan and trans on the trans pan. LolLesson learned by that guy. A few others on that forum were complaining about cross threaded oil pan threads etc. Isn't that a common discussion here?
You would think that manufacturers would have the letters like ATF, OIL, DIFF or something stamped on the ends of those bolts, but wait. That would cost extra money and of course it's all about maximizing profits to them. I will never use a quick lube place. I haven't used one since the early 90s. Those quick lubes will continue to remain in business and we will continue to discuss their shortcomings.
You would think that with the millions of Tacomas, Tundras, 4Runners and FJs that use that transmission....it would mean that these guys have seen them before...many times.This is a common issue with Tacomas and 4Runners. Numerous reports of it happening on tacomaworld.
