Patman,
This extended drain test was run with a Gulf Coast by-pass filter - not exactly a good example.
With this setup, the TP elements are typically changed every 3k-5k miles and a quart of fresh oil is added each time. Heck, I could run any Group II petroleum oil with this setup and get 20,000 miles out of it. You are essentially doing a continual oil change with the Gulf Coast system, as Bob himself has pointed out.
Show me an instance where Mobil 1 was run for 15k-20k miles with just a full flow filter change and topoff halfway through - and no other makeup oil added. I do that all the time - in fact I often run the same oil for two full years in my Toyota, since I only put about 10k/year on the engine.
It is true that you can run Mobil 1 for 10k-15k in the new BMW and Mercedes engines with the flexible service schedule. However, those engines are designed to hold 7.5-8.0 quarts of oil, so there is much less stress on it ....
