As we talked about last night, sometimes it could be less and some times it could be exponentially higher. This is why trending is so important!quote:
Originally posted by BOBISTHEOILGUY:
I'm sorry but I do not agree. Wear #'s are not linear to mileage. Of course you'll see increases but not to those degrees necessarily and are not absolute.
I havn't heard anything about the tests yet. I'm sure when they come out they will be put on the comparison graphs when it does.quote:
Originally posted by VaderSS:
msparks,
Do you have any info on the Amsoil vs Mobil 1 test I was informed of?
quote:
We did some preliminary in house testing on Supersyn. We’re probably going to revise some of our comparison graphs showing this product and some of the other new products on the market. After the independent labs confirm the test results we will make a corporate statement. For now I can tell you that what we found so far is a good but unremarkable product. The baseline showed no “trick” ingredients, and appears to be simply the Mobil Tri-Synthetic with slight chemistry changes to meet the API SL standards. The TBN was a little weak, but they are not looking at extended drains the same way we are. On the light duty 4 ball it scored quite well with a .35mm scar. It didn’t do so well in the more severe 4 ball test scoring a .60mm scar. This compares to 037 for TSO. We’ll have more info coming up.
[/QUOTE]quote:
Answer I recieved from Amsoil;
I agree wholeheartedlyquote:
I run Mobil 1 because I can buy it at Autozone or Walmart. I am sure it's better than Tri which was better than AF, when Mobil brought out the Tri, everyone started talking about it being worse, it wasn't. It's interesting that everytime one of the other companies makes improvement, everyone applaudes, but every time Mobil 1 improves, everyone boos. Unless something comes out in anaysis that it is no good, I'll use it. Been using it with excellent results for over 10 years now...
I wish I could buy Mobil 1 @ $4.00/quart. It sells here for $4.80 to $5.00/quart depending on where you go.quote:
Originally posted by Ted Kublin:
Mobil 1 is a very good product, however since they are formulating it to sell @ $4.00/qt, they are somewhat limited in terms of the basestocks and additive chemistry they can use. The Delvac 1, 5w-40 synthetic diesel oil is a better (but more expensive) product, with a more robust additive package.
There is no secret to making a long drain synthetic oil - it is simply a matter of $$$$ and experience.
TooSlick
Come on up to Canada! We've still got boatloads of the TriSynthetic Mobil 1 for $6.35 per liter up here (or $5 a liter if you find the 5L jugs!) and at $6.35 per liter that's about $4US. Of course it would cost you more in travel expenses to get here, but you guys could visit the Patman while you're up here!quote:
TooSlick
