Amsoil in GM 3.6L DI engine?
Oakville, Ont., Canada
Is anybody using any of the Amsoil oil products in their new GM 3.6L DI engine? I don't see their oils certified under GM6094M and only XL series of oil has been API certified. The *official* answer from Amsoil is that they don't necessarily go through every single spec in order to save certification money. Can any of the Amsoil sponsors here please help? Will putting an Amsoil oil in the engine void the new car warranty? Their oil's NOACK is really low and that's what I'm thinking of using their product in the engine. TIA.
I'm NOT a Amsoil sponsor (or dealer) but....
Will the use of Amsoil VOID your 100,000 mile warranty? No. Will it make it more of a hassle *IF* you have problems? Yes...
Follow the manual for what to use. Make sure you get everything as far as receipts and logs just in case.
With a NEW type of motor, I'd play it safe beyond..
If the motor does not call out for syn, GM is not going to get on your case if you run Amsoil XL oil since its API SL/SM.
Just my thoughts.
Bill
I've used Amsoil for years and would never hesitate to use their products based on the lack of API certification. According to Pennzoil, the deposits on the intake valves of DI engines is due to VI, not volatility in general.
I would use a good synthetic oil and change according to the OLM on the car. (dont extend them) IMHO
Discuss this with your dealer service department. If they approve Amsoil, get the approval in writing.
Just my thoughts.
I think we just wait around for a comment like this in any thread with Amsoil in the title; it's telegraphed anymore...
I use Amsoil in my GM 2.0 DI motor.
They don't dish out the $$ to get certified for spec's that they FAR exceed sometimes. It doesn't mean the oil doesn't at least meet the spec though.
No, Amsoil will not void your warranty. Look up the Magnuson-Moss Warranty Act. A manufacturer cannot void your warranty due to your choice of oil, that meets the necessary specifications...like GM 6094, unless they provide the oil they prefer free of charge, and so on and so forth.
Feel free to use as you wish. I have 7k+ on the SSO (0w-30)I have in my motor currently with no intentions of changing it out anytime soon.
So, following your words...
Amsoil is NOT certified for the necessary specs but the Magnuson-Moss you quote STATES they can not void IF you USE a oil that meets (ie being CERTIFIED) their specs.
I'll STAND by my advise. I would not FOLLOW yours.
Bill
Just my thoughts.
Bill
I agree with Bill. You don't want a hassle if you have problems. These DI engines are new and UOA indicates they're very hard on oil. https://bobistheoilguy.com/forums/threads/winter-run-of-petro-can-0w30-in-gm-3-6-l-di.129033/
I'm not sure a low NOACK oil is going to help. NOACK tests for volatility in high temperature conditions with clean oil. Fuel dilution contaminates oil and NOACK doesn't test contaminated oil.
Originally Posted By: oilboy123
Just don't have the dealer install the oil, and don't tell them you are using a non API certified oil.
.... problem solved.
You surely are not serious about this advice. I assume you are joking.
Listen to Bill in Utah's advice, just use an API certified oil until you are out of the warranty period. Don't mess with it.
The idea of a oil failure is slim to none.The idea of a service dept asking if the oil is API certified is slim to none.I handled hundreds of warranty claims and aftermarket service contract claims.If the engine was not obviously sludged up I was NEVER asked brand or weight of oil in a motor,Trans or differential.
There is no issue here - use the 'XL' line of Amsoil oils, and you won't have a problem. That's why Amsoil HAS the XL line - for situations just like this!
I agree with Bill. However, I would not blindly follow the manual with respect to viscosity, the use of conventional oil, and length of interval the OLM likes to dish out.
This engine has beat up good syns in under 5k, so I can't imagine many conventional oils being up to the task of going the full interval as defined by the OLM without serious long term effects to the engine.
There are a lot of certified oil options that will do well in this engine, so choose one that plays well on both sides of the argument (customer/dealer).
Right! And I think it's one of their best oils for OCI's up to 10k.
Trust me, the mfg has used whatever they recommend in the manual for MANY MORE MILES than ANY of us will EVER run with the engine.
See I don't know what they call for in the manual but they have used it.
Just because something is syn does not allow it to go xx miles. Esp in a new type motor that the OP has.
Bill
Well I have. And I had only one.
Bill
:sigh:
"Absolutely not! Manufacturers’ warranties are based upon the use of oils meeting specific API Service Classifications, for example, SJ/CF. (AMSOIL lubricants meet the current API Service requirements and, thus, are perfectly suited for use in any new vehicle without affecting the validity of the new vehicle warranty.)"
Quote:
If you are interested in using AMSOIL motor oil, but concerned that using a synthetic oil or extending your oil drain interval will void his warranty, you have no need for concern. Congress in 1975 enacted the federal Magnuson-Moss Act to regulate written consumer product warranties. An examination of the law reveals warranties remain intact when AMSOIL Synthetic Lubricants are used.
The law was meant to give consumers detailed information about warranty coverage before they buy.
Congress charged the Federal Trade Commission with creation of the specifics of the law.
The FTC set down three rules under the Act: the Disclosure Rule, the Pre-Sale Availability Rule and the Dispute Resolution Rule.
Those rules require warrantors to title their written warranty as either full or limited, provide a single, clear and easy-to-read document that spells out certain information about coverage and ensure that warranties are available where the products are sold so that consumers can read them before buying.
In passing the Act, Congress meant to give consumers access to warranty information, let consumers comparison shop for warranties, encourage warranty competition and promote timely and complete performance of warranty obligations.
While the Magnuson-Moss Act does not require manufacturers to provide a written warranty, it provides specific rules when one is provided. Among those provisions, FTC regulations state: (c) No warrantor of a consumer product may condition his written or implied warranty of such product on the consumers using, in connection with such product, any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade, or corporate name; except that the prohibition of this subsection may be waived by the Commission if (1) the warrantor satisfies the Commission that the warranted product will function properly only if the article or service so identified is used in connection with the warranted product, and (2) the Commission finds that such a waiver is in the public interest. (15 U.S.C.2302(C))
That means your warranty stands when you use AMSOIL Synthetic Lubricants.
Vehicle manufacturers recommend lubricants according to their viscosity grade and service classification. Any oil, whether its conventional petroleum motor oil or synthetic, meeting the correct viscosity grade, 5w30 for example, and the current API and ILSAC North American service classifications may be used without affecting warranty coverage. AMSOIL motor oils are recommended for use in applications requiring these specifications.
Furthermore, the practice of extending oil drain intervals does not void warranties. Original equipment manufacturers pay or deny warranty claims based on the findings of failure analysis. To affect the vehicle warranty, the lubricant must be directly responsible for the failure. If the oil didn't cause the problem the warranty cannot be voided, regardless of brand or length of time in use.
Synthetic motor oil was introduced to the automotive public in 1972 by AMSOIL, INC., with the world's first API rated synthetic motor oil specially formulated for long service and superior performance and protection to that of conventional oils.
Nearly 30 years ago, AMSOIL synthetics represented a vision of the future and technology ahead of their time. Since then, every major engine oil manufacturer has introduced synthetic oils of their own. To be sure, many original equipment manufacturers would like you to believe you can only use their products. However, it's a violation of the consumer protections set forth in the Magnuson-Moss Act, unless they're willing to provide you those products free of charge.
AMSOIL offers a warranty that covers the cost of repair or replacement of a proven mechanically sound engine damaged as a result of using AMSOIL synthetic motor oil. However, it has never happened. Thirty years of experience proves AMSOIL can be installed in any vehicle with complete confidence.
AMSOIL further backs its products with action when a Dealer or customer reports being told their warranty is voided if they use synthetics.
If you have heard from any member of a business that the use of AMSOIL Motor Oil or the practice of extending drain intervals will void warranties, send AMSOIL all the details including the name of the business, business owner or manager and the individual making the claims, in a signed and dated letter. Send the letter to the Technical Services Department at corporate headquarters and an AMSOIL representative will send them a letter explaining the facts.
Access to the complete Magnuson-Moss Act is available on the Internet by key words Magnuson-Moss Act or Federal Trade Commission.
http://www.amsoil.com/news/2008_worried_over_warranties.pdf
"Another common misconception is that motor oils must be
API certified in order to meet warranty requirements. The
fact is, lubricants are not required to be certified by the API, only meet or exceed API specifications.
"API licensing was originally developed for mineral-
based oils. Petroleum motor oil companies can take
advantage of the convenience and flexibility associated with
base stock interchange, which allows them to buy petroleum
base stocks from any number of suppliers without being
required to re-test and re-certify their products. This ensures adequate supply and competitive pricing. Most synthetic base stocks, on the other hand, are supplier specific and base stock interchange is not allowed. If, for instance, AMSOIL wanted to blend an API-approved motor oil using the same type of base stock from a different supplier, the oil would have to be re-tested and re-certified. This process is both time-consuming and cost-prohibitive. This forces a one supplier relationship that eliminates leverage during price negotiations."
Translation for those in need:
If the oil is proven to meet or exceed the spec classification...then it is perfectly fine to run. If you would like to challenge this, purchase the oil and pay for an API test. Expensive way to find out that they aren't bluffing...
I've had plenty of folks try to argue this lousy point before because they just wanted it so bad not to be true. It doesn't prohibit you from pouring whatever oil you you so choose in your vehicle. Get over it already.
If the motor is "hard" on Amsoil...in Canada...in the winter...it is going to be easier on cheap oil how?
ILSAC syns are cheap?
If by cheap oil you mean a conventional oil, then I would agree that he shouldn't use a conventional oil.
The issue is with API certification, not syn vs dino.
