Originally posted by wulimaster:
Originally posted by TECH:
I figure that if Syntec could work to that mileage, then Amsoil should too, especially using better filtration.
I wouldn't assume that considering you are talking about two different vehicles. I remember reading about sludge problems on the Dakota but I don't recall the years or the engine that was experiencing them. You will have to check another forum for that info. If yours is one of the sludge prone then that could explain the excess thickening.
Yeah, all the 4.7 engines will do it in cold weather and short trip driving. Mine did it a winter ago when I only drove 4 miles to work. I was concerned at first, because a LOT of yellow snot was building up in the oil fill tube. From what I gathered, it was due to the PCV system pulling the crankcase vapors up through the plastic fill tube (cooler area), just below the cap, and the cooling fan air would aid in condensing all the blowby gasses and moisture.
I was certain that some of that condensation was contaminating my oil. When I changed to the Amsoil (still cool climate) I noticed that when the last bit of oil came out of the pan, there was a small trail of yellow coming out with the oil-very slight, but it was there. I took this as being moisture that was on top of the oil, draining down from the tube.
Changing to Amsoil didn't change the snot level. I removed the oil fill tube, and wrapped the whole thing with insulated tape, to help retain heat in the tube, and reduce the affects of the outside airflow around it. That helped a lot, but it doesn't eliminate it.
Basically, the engine needs to be hot for a length of time to burn off the moisture in the crankcase. Since I'm now driving my truck longer distances, I haven't noticed any at all.
On another note, I've seen the same thing in PCV valves on BMW's, they just aren't visible.
