Affordable accurate torque wrench for spark plugs
+1 an anything Tekton. Their good quality and not overpriced.
I bought a few torque wrenches before I knew of Tecton and bought one. And wish I had know of Tekton before buying the lower quality ones. I could of had the better quality Tekton at the same price I paid for those lower quality ones.
For the cost, the accuracy and repeatability of these are pretty hard to beat. And let's be honest, plus or minus 5% on a torque wrench isn't going to amount to anything. As long as it repeats within that range. These do. It's just not necessary to spend hundreds on a torque wrench.
I do like the AAA batteries over the small wafer cells. A couple of Lithium AAA's will run circles over those tiny wafers as far as longevity.
The OP asked about a torque wrench to install spark plugs. That means a wrench with a fairly low ft/lbs range and not one that goes up to 100 ft/lbs and beyond that would also be used to torque lug nuts and other items.
I have one of the high torque level wrenches but decided I needed one that would be accurate at the lower ranges. And I wanted a digital one that came with a certificate of calibration. Affordable ? I guess that's relative. I bought this one and use it for things like oil drain plugs and cannister oil filters that require torque in the neighborhood of 25 ft/lbs. I'm completely satisfied. It is easy to change the readout from ft/lbs to Nm and you can set it to beep when the desired torque is reached or watch the readout as it increases and then beeps.
I use inexpensive Harbor Freight wrenches for general tasks but decided I wanted a higher quality item when it came to a torque wrench that would be used on parts that could easily be over torqued or broken if the wrench was way off on its readings.
https://www.amazon.com/ACDelco-ARM601-3-Digital-ft-lbs-Notification/dp/B004VYUQI2/ref=sr_1_6?crid=1J15BDOHM71F2&keywords=ac+delco+digital+torque+wrench&qid=1668263857&sprefix=ac+delco+digital+torque+wrench,aps,1010&sr=8-6
Cold engine always.
a) Tighten to collapse crush washer (don't reuse) then a little extra tug.
b) Gasket-less plugs follow manufacturers instruction on tightening angle after seat contact.
note: I will use a torque wrench on most sport bike engines.
I haven't purchased a new wrench in a while so I can't recommend.
IIRC we have a click `snap-on 2 footer and a beam torque for low TTY torque jobs - like Asian cam box assembly.
Those numbers seem a quite high even for generalities.
The threads on a typical plug are 1 mm give or take, so one turn moves them in 1 mm. The crush washer will easily crush 1/2 mm or more so 1/2 to one turn is reasonable. Obviously you don't go gorilla on them and after installing a dozen plugs, you get a feel for what is right.
From what I'm seeing, "AC Delco" is like "Bell & Howell". A Chi-Com manufactured variety of products, with an American name that insinuates differently. With Harbor Freight you know it's most likely Chi-Com, because that company was built on that manufacturing premise.
I have nothing against Chi-Com manufactured goods. And I own several Chi-Com tools. But in the case of the digital torque wrench adapters that were tested in the Youtube video above, the "AC Delco" was almost twice as much, and probably came off the same assembly line.
It was just badged and packaged differently. The guy even mentions this in the video.
If it does exists, it will be used to torque spark plugs, ranges from 13-18 ft lbs.
I prefer 3/8 if possible.
Is there a significant difference from digital vs standard?
Appreciate any recommendation or suggestions.
Depending on the vehicle, getting the wrench into position will be the biggest challange. This 1/4 inch Tekton with a 200 in lb limit might be good. You can get 1/4 inch drive spark plug sockets.
Wouldn't it be more accurate to call them Com-Chi?
We have fallen so badly that now when an idea for a product originates in the US it says in big bold letteres "Designed in the USA" and in small font "Manufactured in China". It's ridiculous!
I have to agree with this post. Sometimes you need to spring for a little more; a torque wrench is the perfect time to do so.
