(Had this question in another thread, but it was apparently falling off the radar - it received no comments/answers. Thus throwing it back out in its own thread. Editing the original for clarity.)
Question on AEHass criteria for pre-op temp protection -
You can read the spec of an oil and see the visc. at 40degC, 100degC and (cold pump visc.) -30degC. So I'm thinking the 40degC level is key to wear protection per AEHaas' criteria as defined in his oil visc. article (for the majority of Americans for the majority of the year) - ie, having good flow during first 20-30 minute of op. But is visc. at 40degC indicative of flow just under that temp, and then on up to 100degC. One of my attractions to Schaeffers 7000 5w30 is the (for me unheard of) visc at 40degC of 47-52 cSt. I've perused many a PDS, and I ain't never not seen 40degC visc anywhere near that for a 5w30. If I've discerned this correctly, then Schaeffers 7000 5w30 is a trump card in pre-op temp protection. Plse advise if my thinking is muddled or troubled.
BTW, guys in Houston TX today (and Little Rock AR (100degF w/ 110 heat index expected today)) are thinking flow at pre-op temp doesn't apply to them (at least not today). But if I'm reading Haas' article correctly - the issue still applies. A bottom line I (trust I) understood from Haas article is - an does NOT lubricate properly till it's at op temp (multiple chemical and physical reasons why this is the case). To put it bluntly, if it's 110degF outside and you start your engine, your oil is not working lubricating properly.
So, back to the question - is the visc at 40degC a good indicator of pre-op temp protection for the majority of Americans for the majority of the year?
Thanks!
Thanks!
