- Messages
- 1,644
- Location
- California
In the never ending quest to find the "best" conventional motor oil, I thought I'd compile some numbers on various oil attributes and evaluate them accordingly. All of these numbers were taken from the manufacturers' "product data sheets," and I'm taking it on faith that their numbers are reasonably accurate. I chose not to use data from the virgin oil analyses in these forums. A thread by Greg Bohn poses questions on what can be accurately deduced from such lab testing (Thanks, Greg!). Greg's sample of the same virgin Valvoline oil, sent to three labs, produced some inconsistent results. Examples include: calcium 1,655, 2,149, 2,642; zinc 836, 1,071, 1,382; magnesium 0, 5, 8; TBN 6.43 and 8.7.
From commonly found retail brands, I've included the following manufacturers' test criteria:
-Degrees F Flash Point "FP" (ASTM D-92)
Temperature at which oil begins to vaporize (burn). Can be an indicator of the quality of base stock. Higher numbers are better.
-Degrees F Pour Point "PP" (ASTM D-97)
Oil fluidity at low temperatures. The lower the number, the better it will flow at cold temps.
-Viscosity Index "VI" (ASTM D-2270)
Change in viscosity over a given temperature change. A factor in wear prevention. A higher number indicates lesser change -- higher is better.
-High Temp/High Shear Viscosity "HT/HS" (ASTM D-4683)
Measure of protection under high temperatures. Higher numbers are better.
-Total Base Number "TBN" (ASTM D-2896)
An oil's reserve alkalinity. A higher number indicates enhanced long-term ability to control acids and other contaminants.
-% Sulfated Ash "SA" (ASTM D-874)
The residue remaining after an oil is burned. Lower is better.
-% Zinc "Z"
An extreme pressure, anti-wear additive. More is better, yet more also results in increased combustion chamber deposits. Therefore a balance is necessary, often around 0.11%, more for racing oils.
I did not include such criteria as Four Ball Wear Test, % Calcium, % Magnesium, % Phosphorus, etc., since a majority of manufacturers do not provide this info. Motorcraft's spec's refer to SJ oil and are outdated, and Castrol and Shell evidently don't provide data sheets for their conventional oils -- too bad for us dolts who can't be trusted with such info. For anyone who can provide some good insight into the data below, please do so!!!
Component numbers below are in order: FP, PP, VI, HT/HS, TBN, SA, Z
***5W-20 SL***
Chevron Supreme: 460F, -27F, 148, ---, 8.3, 0.9%, 0.112%
Citgo Supergard: 421F, ---, 154, 2.6, ---, ---, ---
Kendall GT-1 High Perf.: 432F, -38F, 150, 2.6, 7.4, 0.90%, 0.11%
Mobil Drive Clean: 392F, -26F, 153, ---, ---, ---, ---
Pennzoil Multigrade: 445F, -49F, 158, 2.65, ---, ---, ---
Phillips TropArtic: 448F, -31F, 156, ---, ---, ---, ---
Quaker State Peak Perf.: 445F, -27F, 151, ---, ---, ---, ---
Texaco Havoline: (same spec's as Chevron)
Union 76 Super: 430F, -33F, 157, 2.7, 8.0, 0.92%, 0.108%
Valvoline All-Climate: 428F, -38F, 157, ---, ---, 0.92%, 0.105%
COMMENTS ON 5W-20: Chevron, Texaco, Pennzoil, Phillips and Quaker State like the heat, Mobil does not. Pennzoil, Kendall and Valvoline flow well in extreme cold. Chevron and Texaco have a slightly higher TBNs.
***5W-30 SL***
Chevron Supreme: 450F, -33F, 159, ---, 7.4, 0.9%, 0.103%
Citgo Supergard: 442F, ---, 154, 3.2, ---, ---, ---
Kendall GT-1 High Perf.: 421F, -40F, 152, 3.0, 6.2, 0.80%, 0.10%
Mobil Drive Clean: 392F, -38F, 159, ---, ---, ---, ---
Pennzoil Multigrade: 420F, -44F, 160, 3.1, ---, ---, ---
Phillips TropArtic: 410F, -30F, 155, ---, ---, 0.8%, ---
Quaker State Peak Perf.: 405F, -27F, 159, ---, ---, ---, ---
Union 76 Super: 420F, -38F, 154, 3.1, 6.2, 0.80%, 0.099%
Valvoline All-Climate: 403F, -38F, 162, ---, ---, 0.8%, 0.105%
COMMENTS ON 5W-30: Chevron, Texaco and Citgo like the heat, Mobil does not. Pennzoil flows well in extreme cold. Chevron and Texaco have relatively high TBNs.
***10W-30 SL***
Chevron Supreme: 450F, -31F, 135, ---, 7.4, 0.9%, 0.103%
Citgo Supergard: 451F, ---, 137, 3.0, ---, ---, ---
Kendall GT-1 High Perf.: 421F, -29F, 135, 3.1, 6.2, 0.80%, 0.10%
Mobil Drive Clean: 392F, -33F, 134, ---, ---, ---, ---
Pennzoil Multigrade: 430F, -33F, 140, 3.2, ---, ---, ---
Phillips TropArtic: 432F, -33F, 139, ---, ---, 0.8%, ---
Quaker State Peak Perf.: 410F, -22F, 139, ---, ---, ---, ---
Union 76 Super: 420F, -33F, 136, 3.1, 6.2, 0.80%, 0.099%
Valvoline All-Climate: 421F, -27F, 135, ---, ---, 0.8%, 0.105%
COMMENTS ON 10W-30: Chevron, Texaco and Citgo like the heat, Mobil does not. Quaker State doesn't flow quite as well in extreme cold. Chevron and Texaco have relatively high TBNs.
***10W-40 SL***
Chevron Supreme: 453F, -29F, 148, ---, 7.4, 0.9%, 0.103%
Citgo Supergard: 455F, ---, 148, 3.6, ---, ---, ---
Kendall GT-1 High Perf.: 419F, -26F, 146, 3.6, 6.2, 0.80%, 0.10%
Mobil Drive Clean: 392F, -27F, 147, ---, ---, ---, ---
Pennzoil Multigrade: 415F, -33F, 153, 3.7, ---, ---, ---
Phillips TropArtic: 424F, -33F, 145, ---, ---, 0.8%, ---
Quaker State Peak Perf.: 430F, -22F, 148, ---, ---, ---, ---
Union 76 Super: 420F, -33F, 147, 3.8, 6.2, 0.80%, 0.099%
Valvoline All-Climate: 421F, -27F, 148, ---, ---, 0.8%, 0.105%
COMMENTS ON 10W-40: Chevron, Texaco and Citgo like the heat, Mobil does not. Pennzoil and Union 76 have a slight edge in extreme cold. Chevron and Texaco have relatively high TBNs.
***20W-50 SL***
Chevron Supreme: 496F, -20F, 122, ---, 7.4, 0.9%, 0.103%
Citgo Supergard: 473F, ---, 121, 4.6, ---, ---, ---
Kendall GT-1 High Perf.: 446F, -26F, 124, 4.3, 6.5, 0.85%, 0.11%
Mobil Drive Clean: 392F, -17F, 124, ---, ---, ---, ---
Pennzoil GT Perf.: 450F, -11F, 130, 5.1, ---, ---, ---
Phillips TropArtic: (Not on my spec sheet)
Quaker State Peak Perf.: 441F, -6F, 120, ---, ---, ---, ---
Union 76 Super: (Not on my spec sheet)
Valvoline All-Climate: 446F, -11F, 125, ---, ---, 0.8%, 0.105%
COMMENTS ON 20W-50: Chevron, Texaco, and Citgo like the heat, Mobil does not. Quaker State doesn't flow quite as well in extreme cold, although no 20W-50 is really a cold weather oil. Pennzoil has good VI and HT/HS numbers. Chevron and Texaco have relatively high TBNs.
FINAL COMMENTS: What's my own admittedly controversial opinion on what's the "best" conventional oil? Easy. The differences between the major brands appear to be more subtle than substantial, so for the average Joe to whom "severe service" does not apply, the "best" oil is simply the least expensive name brand, SL-rated, proper weight oil you can find at any given moment. Now how's that for controversy!
