The short answer to the question about if there is any kind of problem? " YES ".
The long answer is a little more complicated. The following is a copy of a post I made on 2/9/10:
Aluminum and Copper are on the opposite ends of the electro negativity chart. They can be used to make a great battery. In other words when both are in the same cooling system expect very bad things to happen. Also note that Brass has Copper in it. Could be a Copper radiator and something else such as metal radiator mounts vs rubber radiator mounts, or the rubber mount(s) might be missing, and or improper cooling solution.
? How do you get new Copper gutters to fall off of a building one year after you put them on?
Answer: Put them on with Aluminum roofing nails.
? How do you get a new $125,000 Aluminum injection molding machine to be a useless hunk of metal one year after it is installed?
Answer: Use brass fittings on the water cooling jacket connections.
You know where the Aluminum is. Where is the Copper? Probably the Radiator. What is different regarding this vehicle that allowed the electrons to flow from one metal to the other metal, where in other vehicle with aluminum blocks this does not happen?
Some possible answers are: Wrong type of metal radiator used with Aluminum block, or metal radiator mounts instead of rubber, or radiator touches frame completing circuit to allow battery action with Aluminum block and Copper radiator (coolant is part of the circuit, it might require metal connection (through the frame of the vehicle) to complete the battery corrosion action). Or coolant that is too acidic. I do not know the specifics of this vehicle. I am just talking about the electro chemistry probably involved here.
PS: The elevated temperatures inside of an engine speed up this battery action.
However, note, there must be a complete electric circuit for this problem. Sometimes rubber electrical isolation mounts are all all that is required to protect against this problem. But if you are not sure you are better off staying away from using dis-similar metals (especially if they are far apart on the electro-negativity chart).
