Summary – thinking about using one transmission cooler with ATF sandwiched in between two other transmission coolers full of coolant to create a durable heat exchanger – goal is to prevent blown tank separator walls and fluids mixing.
Need to add an oil-to-water heat exchanger for my 2006 Allison 1000 transmission in a custom 12-valve Cummins offroad truck to help transmission warm up to operating temp in cold weather. Heard too many stories over the years when either an internal radiator ATF tank leaks or a stand-alone heat exchanger (like on RAM or BMW or Nissan) busts a weld or somehow gets a hole in the wall separating fluids. Which usually leads to the transmission being flooded with coolant. My current HD radiator is made for coolant duties only with no other fluid ports. Additionally, Allison transmission cooler lines output 85 PSI at idle and can spike above 200-230 PSI under load, which is 2x-3x more pressure than most other car auto trannies and may exacerbate the “blown wall” issue.
Looked at a bunch of different heat exchanger designs, including marine, and most of them have flaws that can cause leaks. It’s also hard to find an ATF cooler or heat exchanger rated for over 300 PSI (many are 150 PSI rated). There’s only one unit by FSD called “Billet Aluminum Heat Exchanger” that seems pretty solid. But it’s pretty pricey too, of course, having been made from solid aluminum and low volume orders. So I was thinking about building my own “budget” version at least for now to experiment with.
My idea is to sandwich a Duramax cooler (rated for Allison’s higher line pressure) in between 2 other similarly-sized transmission coolers and fill the two outside ones with coolant. That way, the two outside units will fill up with the warm coolant and heat up the transmission fluid in between them when ATF is too cold and the truck isn’t moving yet (or plugged into a block warmer). This will also probably offer some degree of cooling and keeping steady operating temperatures under normal use too. And then run an additional Duramax cooler in front of the radiator to actually cool the fluid down when truck is moving and tranny gets too hot.
Thoughts? Feedback? Criticisms? Suggestions for improvement? Alternatives to consider?
