Hi, All--I'm new to this forum, but I am on many others around the Internet, and have been for decades.
I am currently intalling a Chevrolet Performance Connect and Cruise LT1\8L90E "E-Rod" into a 57 Chevy Sedan Delivery
For the transmission cooler, I will have a cooler in the radiator, and am using a DeRale 13960 External auxiliary cooler with fan
The DeRale specs state that the volume of this cooler is 16 FL OZ.; this, and the cooler in the radiator plus the lines are going to require some additional fluid to be added to the transmission--possibly as much as a quart after all is said and done, and I want to get it into the coolers and lines before I attempt to start the engine up . . .
In the Instructions that came with the Connect and Cruise kit, it states to ONLY use Dexron HP transmission fluid in the transmission, but after trying to find some and researching further, I found that Dexron HP apparently is no longer being produced, and has been superceded twice by other GM part numbers, the latest one seems to actually be Mobile 1 LV HP . . .
Since this engine/trans were built sometime in 2020, I need to know what fluid to use . . . do I need to go to a GM dealer and buy the latest Dexron HP part number, or can I use the Mobil 1 LV HP fluid, because the superceded part numbers occurred BEFORE this transmission was even built, so I have no idea what fluid was used to fill it originally . . .
Can someone please clarify which fluid I actually need?
Thanks in advance!
Thanks in advance!
