Was perusing the web for info about a remedy for my P/S whine in my 2013 Suburban . Getting lost in the weeds about which fluid, etc. etc.
Came across a TSB (service bulletin) from GM "SB-10052379-4090"
Says to flush and replace with Dexron HP for power steering cold weather.
"Flush the power steering system and refill with DEXRON HP power steering fluid. Provide the customer DEXRON HP fluid Part Number information for their records for any future maintenance needs. Parts Information DEXRON HP ATF, or ATF (212-B) fluid (P/N or spec# 9986333, spec # GMW16444 ) is serviced with bottles: Part Number Description 19300536 32 oz. with English language label. 19300537 (Canada) 1 Liter with English/French language label"
Thought I read that Mobil 1 LV ATF HP is the factory supplier for Dexron HP, but not certain.
