This BITOG implies Toyota and Honda are essentially same. Pink is likely not.Late vote for Toyota Red. My '88 Supra has an iron block, aluminum head, and brass/copper heater core. Originally it had a copper radiator, but I now have an aluminum one. Red excels at dealing with this mix of metals.
Nice.Anything that meets the Cummins 14603 spec.
It seems theI’d still go with an HOAT since everything was designed with consideration of a silicated coolant back when.
As long I I stick with distilled water the Honda should be good.Acura/Honda coolant is P-HOAT (Phosphated HOAT), and HOAT is Hybrid OAT, Phosphate-free
It seems the
It seems theAs I recall, Honda Type II is silicate free. Not 100% sure if/why they call it a HOAT given no silicate.
But I would validate that. IMO you want silicates in this antique.
Super flushing can likely yield an ok result, but for peace of mind personally I’d want silicate in a system designed for it.
quote was wrong - type 2 is a POAT.Acura/Honda coolant is P-HOAT
.CAPACITY (US QUARTS) 27
Refill the cooling system with water and protect
against corrosion by adding Cooling System Rust
Resistor, Part Number 2421778, or refill with water and
Permanent Type Anti-Freeze, Part Number 1316209,
depending upon the season.
That's the way I remember it, both G-05 and G-48 are silicate containing HOAT coolants. With the G-05 being 2-EHA free, but G-48 may contain 2-EHA depending on who made it.Years ago I was comparing and I thought the main difference was the addition of 2-eha. Not silicate concentration.
