One more car to ask about!
I purchased this car with 210k on the clock and despite its generally good health I opted to go ahead and replace the rings and bearings while I had it partially torn apart. Prior to the rebuild I changed the oil once using castrol synthetic blend and a PL24457 filter.
This car will be used mostly for Auto-x, track days, and back road fun-- but won't be seeing what I would consider enough of a level of abuse to warrant using redline oil in the motor.
I am unsure of the recommended oil for this motor(KA24DE) but i'm assuming it is 5w30 or 40.
What do you recommend for the post-rebuild break in and longer term use- Both for the oil and OCI?
ps- Thanks for your recommendations on the MTL for this car a while back, the MTL/MT90 mix will be going in the trans as soon as its back on the road.
