Originally Posted By: sdude2k2000
Bottom line - If the manual / oil cap says 5w20, run 5w20. If you want to run 5w30 because the whispers in your ear say to, then run 5w30 instead. If you want to UOA to see which works best, okay.
The manufacturers specing other oils in the rest of the World for the same engine is more than a whisper.
No it's not. It's the oil companies catering to those country's populations who have always run thicker stuff because "that's what we do!".... much like the arguments I hear in here from the "thicker is obviously better!" crowd.
What if you
know, for a fact, that your engine was manufactured from 1997-2008 and that the internal clearances and tolerances had
NEVER changed in all of those years? And, that said engine was originally spec'd 5W30 oil from 1997-2000? Then, in 2001, for CAFE reasons, it was then spec'd 5W20?
Interesting dilemma, huh?
So, no, it's
NOT the bottom line!
Ignorant statement based on your personal feelings / opinions of CAFE. Nobody will argue CAFE moved the oil industry forward and towards lighter grades, but that doesn't mean they can't protect every bit as well as a 30-grade
in approved applications. Police vehicles, taxis, etc are subjected to the harshest oil conditions imaginable in a PCMO application (heavy stop & go, a lot of idle time, etc)... and their vehicles run just fine and dandy on 20-weights. used oil analysis and engine tear-downs have proven that time and time again. So until you provide something beyond your opinion on CAFE, what I said really is the bottom line... run whatever makes YOU happy and helps YOU sleep better at night.
I have nothing against CAFE. Look at my signature. Just because "YOU" say it's the bottom line doesn't necessarily mean that. Remember, the same tests that were conducted on 20 weights were also done with 30 weights. I was merely stating that just because "YOU" say to use what the manual reads or the oil cap reads, is not always the case. If it was originally spec'd for a 30 weight there is no reason to not run a 30 weight.
And, yes, I do sleep better at night knowing that "I" can decide which oil to use and not be told what to use.
