Originally Posted By: BlueOvalFitter
Originally Posted By: spasm3
Originally Posted By: Tony10s
Originally Posted By: dothedrew1202
sorry for the dead horse, I'm out on my phone so I can't really search. I saw Kendall full syn for 2.99 at my 99 cent store but it was only 5w30. Would you put it in a 5w20 still under warranty?
I have used 5W-30 motor oil in my Elantra, which has 5W-20 on the oil cap; however, my manual says that 5W-20 is recommended, but 5W-30 can be used as well (and also 10W-30 for temperatures > 0 deg F).
Same thing in my elantra, in fact the owners manual states you many need a heavier oil in hot weather.
I run 0w or 5w 20 in the winter and 5w 30 summer.
I don't understand why you, and others like you, just don't use the same weight oil during all seasons. I am not dogging you, or trying to be sarcastic, or even trying to ruffle your feathers. I mean, the oils you stated in the sentence I quoted, are so similar to each other that you can just pick one and use it all year round.
Ah well, if you sleep better at night doing it your way then go for it!
I am guilty of something similar; I always use a new oil filter at every OCI and some members dog me for that; the ones that think that at each OCI, instead of throwing the used oil filter away, use it again. And, my answer to that is,
"One Filter, One OCI!"
The chart in my Elantra owner's manual shows that both 5W-20 and 5W-30 can be used for the exact same temperature range (the same on the cold side and hot side); thus, either 5W-20 or 5W-30 can be used year round in my car. The only viscosity that shows a different temperature range is 10W-30, which can be used for temperatures 0 deg and above. Therefore, from now on, I will only be buying 5W-20 motor oil for this car. There's really no reason for me to use different viscosities for the winter and summer.
