The guy is just aimlessly trolling at this point.In terms of lubrication of the crankshaft and rods, the soft component is the journal bearings. What's that got to do with oil burning?![]()
I don't think so ... seems like some cut and paste off some hack oil site.Is this supposed to be a joke???
Reduce the weight of a race car....Did you know that
What Weight Oil Do Race Cars Use?
Race cars typically use a very lightweight oil, such as 0W-30 or 5W-30. This helps to reduce the overall weight of the car, and also helps to improve fuel economy. The lighter weight oil also flows more easily at high temperatures, which is important for race engines that operate at extremely high temperatures.
Yep ... the film thickness changes as the piston/rod assembly goes through it's 4-cycles and the pressure on the oil film increases and decreases. The oil film is essentially acting like a cushion against those dynamic loads. Rod bearings see a lot more of this than the crankshaft bearings, and that's why rod bearings take more abuse and fail before crank bearings. Also, as the oil becomes thinner, the MOFT is much more likely to go to zero somewhere in those 4-cycles.Film thickness is most certainly a cushion, it isn't about flow. Every engine needs the cushion that the MOFT provides, otherwise there is metal-to-metal contact and failure occurs.
An entire website about it ?Tolerances... oil having to flow through small ones...
Whatever next for that poor oil?
of those often very "hated" boutique oils like Amsoil, Shaeffer's and HPL. Thanks for great belly laugh!!! Both of our cars are not worth $50,000 together.![]()
I don't remember the RPMs ever changing when my Hondas have engaged VCM. Honestly, most of the time, the only reason you could tell was because the Eco light would light up on the dashboard.Since PD pump (godfather of thin vs. thick flow rates) and M1 0W-40 (godfather of manly oils) have been discussed in this thread ... lol, I am now curious if the RPM also increases (jumps up a little automatically) when the VCM or the cylinder deactivation mechanism is activated? Don't mean to hijack but it is kind of related to the heat topic.
The J35 Honda V6s do not have any issues with fuel dilution and it is certainly not caused by VCM. VCM causes other issues. The Honda 1.5 turbo DI engines do have an issue with fuel dilution but they do not have VCM.The VCM system is known to cause significant fuel dilution in these vehicles. Ask yourself why the computer is set for 5k mile oci’s when most newer cars are 10k-15k mile oci’s. By using a 30wt you are giving yourself a cushion as the oil becomes thinner due to fuel dilution. Starting with a 30wt @ 10cst that becomes a 20wt @ 8cst after 5k miles is much better than starting with an 8cst that dilutes down to 6cst. 20wt’s are recommended solely for CAFE purposes. As many have said look up your vehicle oil specifications in other countries and you will see what oil weight the engine was designed for![]()
Still worth checking UOA before making any decisions.The J35 Honda V6s do not have any issues with fuel dilution and it is certainly not caused by VCM. VCM causes other issues. The Honda 1.5 turbo DI engines do have an issue with fuel dilution but they do not have VCM.
Wife and I didn't notice anything on the 1,500 mile journey back when buying our van.Since PD pump (godfather of thin vs. thick flow rates) and M1 0W-40 (godfather of manly oils) have been discussed in this thread ... lol, I am now curious if the RPM also increases (jumps up a little automatically) when the VCM or the cylinder deactivation mechanism is activated (shutting down some cylinders)? Don't mean to hijack but it is kind of related to the heat topic.
Just curious: why so many people are scared by fuel dilution? Nothing to worry about, IMO. In reasonable amount, of course.The VCM system is known to cause significant fuel dilution in these vehicles. Ask yourself why the computer is set for 5k mile oci’s when most newer cars are 10k-15k mile oci’s. By using a 30wt you are giving yourself a cushion as the oil becomes thinner due to fuel dilution. Starting with a 30wt @ 10cst that becomes a 20wt @ 8cst after 5k miles is much better than starting with an 8cst that dilutes down to 6cst. 20wt’s are recommended solely for CAFE purposes. As many have said look up your vehicle oil specifications in other countries and you will see what oil weight the engine was designed for![]()
Anatoly,Anything above 2-3% is considered high in the industry. Fuel dilution lowers viscosity and could result excessive wear.
Not always, did not help in my case after 40min drive and fuel dilution still 5%.When engine get warmer, fuel just evaporates from the oil
No. It's not about dreaming the oil "reaches all corners of the engine". It's about the MOFT in the bearings. There is zero benefit to diluted oil, from reduced film thickness to degradation of the VM.Just curious: why so many people are scared by fuel dilution? Nothing to worry about, IMO. In reasonable amount, of course.
When car starts, thinner and diluted oil is a best thing that you can dream about: it reaches all corners of the engine much faster than without being diluted. When engine get warmer, fuel just evaporates from the oil. So no dilution on normal conditions.
Did I miss something?
P.S. In my youth when no multigrade oil was available, gas truck drivers used to add few ounces of gas to the crankcase in the winter. Since usual winter temperature in my home city was/is -15-20C, this makes perfect sense.
Never mentioned 20 grade oils. I mentioned 0wXX and VIIs, because it’s widely known that a super high VI (especially those 200+) have much higher Noack results; it’s not quite, but nearly linear increase as VI increases. Higher volatility = higher amount of oil mist in PCV system = more propensity for IVD.Here's the first time I read where high VII's and 0w20 oils, make GDI valves dirtier sooner.
Hoping thread-starter rbk777 responds to why Mobil-1 EP Triple Action will get his avoidance.
