.455 Webley Ammo
You are welcome. Next would be getting some Moon clips for your Webley because you can't use one without the other. The 3 round clips look interesting. The auto rim case is probably the best solution. The moon clips for the M1917 S&W, or maybe the S&W 25-2, are a starting point. I see gun shows and reloading in your future (y)
"I see gun shows and reloading in your future"
That obvious, huh? <G>
I don't know the specifics of the .455 Webley but the SAAMI max allowed rim thickness for .38 Special is .059 inches and the minimum breechface clearance is .060 inches. That implies a clearance of .001 is sufficient.
Worth a try, then. Thank you.
