Well, I'm at a point where I'm needing to change trucks...not because of miles/wear, etc., but because its a standard cab. I've been a Dodge guy all my life, but this 3rd gen has been less than impressive...steering issues, vibrations, injectors, etc...I've dumped A LOT of money into this truck to make it reliable and durable (I have owned it since it had 141 miles on the clock). It's been a good truck since I've done the mods, but I need a bigger cab for family at this point.
I'm looking for a extended cab/crew cab, 4wd, 3/4 ton (HD, not a glorified 1/2 ton) or single rear wheel 1-ton with an automatic. I will be buying used, probably less than five years old, with low miles...I don't travel the way I once did (my 04.5 sits at 266k). I am hesitant to buy a used diesel, mainly because they are so easy to chip, abuse, unchip, and sell...and you as the buyer are potentially buying an abused truck without much indication. I am thinking that I will probably regret buying a gasser after owning a 5.9 Cummins for the past 15 years (current one is right about 450HP and a 6spd manual with 4.10s, so its got a lot of grunt), but the upcharge for any of the diesels, the price of fuel, and the fact we don't really tow that often...probably a moot point anyhow.
I like the body style of the GM and Dodge, but again; I really don't want to go down that road again with the Dodge. I liked the fact you could get a GM with an 8.1L and Allison, but it appears that combination isn't offered now, and I don't think a Hemi will tow what I have (a 10k GVW trailer and a 8500# 5vr) as my coworker has an 04 Dodge 2500 and it works to tow his camper that weights right around 7500#s. I really don't know much about the Fords...really don't like the latest body style, and I know absolutely nothing of their power train or how they hold up.
So for those of you that have them...how do the newer GM (Chevy/GMC) HDs hold up? What are the Ford offerings in the F250/350, and how do they hold up? What kind of gas mileage are you seeing (realistically)??
What would you chose, and why? Again, I'm not buying new; but it will probably be in the $30k range and less than 30k miles...which seems to be about right for a 2009-ish truck. I guess I need real world experience from others as the sites I frequent are pretty much diesel-only.
