I'm only recommending that oil because you have a BMW.what element is called for cleaning on this oil compared to Valvoline Restore and Protect? as i've just posted in another thread the msds of Mobil 1 0w30 is more of a gtl oil than a pao/ester .ester=cleans. i know Valvoline Restore and Protect has another composition that cleans,not ester,which we dont know.
I think that's a good observation and insight. It also seems that VW engines appear prone to valve stem seal issues as well and develop oil burning from that.Keeping pistons as clean as possible isn't JUST a question of oil. It's also a question of how an engine is used, the fuel used, and the filtration as well.
The elephant in the room is how it's possible that VAG engines can have so many problems with early life oil burning when VW requires the use of oils that have demonstrated remarkable resistance to oxidation and piston deposits.
We have to conclude that the engines are being used in a way that doesn't reflect the test conditions. Keeping engines clean when dealing with fuel dilution and short trips requires fundamentally different chemistry that keeping engines clean when dealing with prolonged high temperatures and higher load conditions.
If you own a VW and drive it hard like it was on the autobahn and run a VW spec oil on half the VW recommended interval, you will probably never have ring sticking or consumption problems, because the usage reflects the test condition.
But stick that same vehicle and oil in a suburban short trip duty cycle with tons of moisture and fuel dilution and you end up with piston ring deposits and oil burning. The DI pack isn't tuned for that condition. It only speaks German
Add to that mismatch an oil drain interval that is much, much too long in the context of that mismatch and you get deposits and chronic consumption.
Nah, the oil is fine. Just be sure you flush any residual Volkswagen from it.@Hohn, I'd better drain that CEB 5w-40 out of my 2GR-FE as soon as I get home.![]()
if driving hard on the autobahn, i think you dont need to cut half the OCI ,maybe a little less .e.x if its 24000,do it at 18000.the reason is that the oil gets temp and works at what it was tested about as you claim.so no harm really, in fact this is how it should work.i have been witness of friends that own a new bmw and do a lot of highway commute and drive hard and keep the bmw oil interval and their car is in perfect condition after 200.000 km.and drive it hard like it was on the autobahn and run a VW spec oil on half the VW recommended interval, you will probably never have ring sticking or consumption problems, because the usage reflects the test condition
No matter what you do or what you use and you still have to use good fuel, make sure your emission systems are up to task and working properly and do the thing that a lot of people don't do and that is to take it out on the open Highway for at least 30 minutes where it has a chance to get up to temperature and hit some of the upper RPMs. Anything with the Pea detergent it's what I recommend but just like zinc, it has to get hot and up to temperature to do its deal. After you've ran it good and hot just like when you put a car away for the winter, park it after you've really driven it that way it has time to heat soak with the fuel detergent and a proper adequate fuel additive.When I first got this Toyota it only had 133 miles on the oil change and I didn't want to change the filter, so I siphoned out and replaced with the last half of a quart of @High Performance Lubricants EC30 and Pennzoil Ultra Platinum 0w20. I ran that for about 3,000 MI and then had a service done with a Napa Gold oil filter and Pennzoil Ultra Platinum. I then recently changed it again leaving the new filter on as it was only 4000 miles and used up the last half of a can of BG Moa in Pennzoil Ultra Platinum 5W20. I have also cleaned throttle body, used TT+ fuel 89 e5 from Amoco along with Redline Si-1 fuel system cleaner.
The higher amount of P.E.A it has the better. Chevron Techron fuel additive works greatNo matter what you do or what you use and you still have to use good fuel, make sure your emission systems are up to task and working properly and do the thing that a lot of people don't do and that is to take it out on the open Highway for at least 30 minutes where it has a chance to get up to temperature and hit some of the upper RPMs. Anything with the Pea detergent it's what I recommend but just like zinc, it has to get hot and up to temperature to do its deal. After you've ran it good and hot just like when you put a car away for the winter, park it after you've really driven it that way it has time to heat soak with the fuel detergent and a proper adequate fuel additive.
If you don't have a whole lot of miles and you want to do a occasional flush I'm not against it but don't go overboard.
I agree, i like Redline for the upper cylinder lubricant and then to reuse the bottle and then buy something like Lucas upper cylinder or lx4 from hotshots and I pour that back in the bottle and just micro treat in between until the next Oil Change along with top tier rated fuelsThe higher amount of P.E.A it has the better. Chevron Techron fuel additive works great
Cool storyWhen I first got this Toyota it only had 133 miles on the oil change and I didn't want to change the filter, so I siphoned out and replaced with the last half of a quart of @High Performance Lubricants EC30 and Pennzoil Ultra Platinum 0w20. I ran that for about 3,000 MI and then had a service done with a Napa Gold oil filter and Pennzoil Ultra Platinum. I then recently changed it again leaving the new filter on as it was only 4000 miles and used up the last half of a can of BG Moa in Pennzoil Ultra Platinum 5W20. I have also cleaned throttle body, used TT+ fuel 89 e5 from Amoco along with Redline Si-1 fuel system cleaner.
What makes it good for valve trains? With all the piston talk here - lifters and rockers still worry me the most …Royal Purple HPS or XPR for not only for great solvency but top notch valvetrain protection. If you can see past the marketing dye that last maybe 20 miles it's an exceptional oil.![]()
