2025 Ram SO Hurricane
Pennsylvania
I bought a new 2025 Ram with the SO Hurricane engine in December. The recommended oil is 0W-20 but I have read some articles that suggest that the 0W-40 that is required in the HO engine is the way to go. I drained the factory fill and replaced with 5w30 for the summer but am thinking about what I will do for the fill this winter in Pennsylvania. 0w30 for the winter, 0W-40, or the recommended 0W-20?
Did you see this thead:
Hard to argue with that report.
Where is the Pennzoil Ultra Platium 0W20 being found? I have not seen it on the shelf locally
Call me the odd man out, I'd run 0W40 if I owned one, especially if I were to tow with it. I watched quite a few videos of guys working that engine, and when they got them real hot oil pressure was quite low, some went into limp mode running 0W20 oil. Flame suit on.
Did they report oil temps in those cases?
Mobil 1 Extended Performance 5w30 year round. A robust long life oil, highly shear stable oil, that handles heat exceptionally well, has adequate HTHS at 3.1 (up from the 0W-20's 2.5 to 2.6) and will flow really well in cold weather.
It has a pour point of -49ºF and according to Mobil, is usable down to -40ºF. My reason for recommending it is the shear stability and very wide temperature capability.
I'd pass on the 0w-20. And I wouldn't push intervals on a turbo gdi engine, I'd do 5k or less to play it extra safe. Use any euro rated 0/5w30/40. Mobil 1 Esp 0w30 is great along with the 5w30. Can't go wrong with m1 or castrol 0w-40. If anything you can swap the oil cap for one that says 0w-40.
I think this was the video you may have been referencing, not sure though. They had a low oil pressure warning at the end.
~21:30
I watched that along with a few others. IMO the oil pressure should never get that low. I've read about people getting pressures a little higher w/o towing in hot climates running up hills and working the engine a bit.
That is old EP.
Current on pour point is -27, or -33c.
Group III, nothing to see there.
Mobil 1 ESP 0W30 all day, any day.
240F oil and 246F coolant temperature I believe, I could be a little off. I was looking into that engine over the winter and there are a few good videos floating around referencing it.
245f oil going up a mountain with a trailer.. and it didnt get low oil pressure until 600rpm idle afterwards.
of course a thicker oil would fix that..
however if you arent beating it up a mountain with a heavy trailer the thicker oil is IMO optional (and I'd run it)
but it is nice to break 20mpg in a full size truck too.. and as long as the oil temps are under 230f 0w20 not likely an issue.
although I'm not familiar with how much these dilute or shear the oil.
I would want at least a regular 30wt (non euro)
at 250f your 40wt is now as thick as a 20wt at 212.
