I have no beef with an engine being used for multiple platforms. Look at the old GM 4.3 V6.True and for some reason that gets chastised on here.
Well, that and the mini-van engine![]()
I do wish they had the 4.0 like what is in the 4R though.
It’s because the highway driving experience sucks.True and for some reason that gets chastised on here.
I’m on 4.88s and have run several tunes. They merely serve to take it from absolutely intolerable to somewhat ok, with lower MPGs.Nothing wrong with a 3rd Gen. IF:
5' 9" or so, or under - seat feels just fine
MT. 6 speed is great transmission
Regear the diffs, 4.88
RWD LOW switch
Tune the engine. There is a LOT of power muzzled in the V6
I added air lockers, F&R
My ONLY gripe, really? Is squeaking clutch peddle at 25K. It's like Toyota didn't test it all. Gonna lube it today.
My friend has a manual Pro. Loves everything about it except backing a trailer. Lol.Nothing wrong with a 3rd Gen. IF:
RWD LOW switch
RWD LOW switch
My ONLY gripe, really? Is squeaking clutch pedal at 25K. It's like Toyota didn't test it all. Gonna lube it today.
Do both 2nd and 3rd gens allow this? I remember seeing something about it years ago, a way to get 2LO.RWD LOW switch
When I bought my current house, I could watch the trans temp spike while backing my trailer up my driveway. Come to think of it, my Camry would smell quite warm after backing up a small trailer up the same incline too.
Nice. Halfway tempted to go look at some Tacos but I know I’m shopping for a vehicle for “me” and not the fam. Thing is, my commute is an hour each way! RAV4 is a smarter choice, probably. But I kinda miss having a truck, and despite not being able to move it, I still own a 6x14 enclosed trailer, for reasons I’m not sure of (other than, it is the right tool for when lots of stuff needs moving).Pretty sure they do. They're pretty similar in nature. I remember reading a post about a 2nd gen 2LO mod, but can't find it.
No, probably not. Loved my Tundra but man, it was as big as my house. But it yanked that trailer around with authority. For now I loan the trailer out, friend of mine uses it a couple times a year. It’s actually not a bad tow, I think 1,600lb unloaded? single axle, so it wasn’t bad on backing up (no tire scrub issues).2013 - 2015 is the sweet spot if you don't want a 3rd gen. Those also probably have less rust issues.
It will not pull your 6x14 enclosed very well though![]()
MT or AT?It’s because the highway driving experience sucks.
Found it. 2LO ModI remember reading a post about a 2nd gen 2LO mod, but can't find it.
Worthy mod, especial with stock gearing trying to back up.Found it. 2LO Mod
That saddest thing about the 3rd Gen Tacoma to me is there seems to me parts of the truck Toyota only "tested on paper".
Been trying to decipher that drawing, think I understand it enough that I could figure it out. What’d be really cool is if flipping the switch would put it into 2LO without having to flip, then set to 4LO. That’d require figuring out how it runs the rest of the system though. Need a factory manual for that. Not going to figure that out, not when I don’t own one!Worthy mod, especial with stock gearing trying to back up.
Yeah I got that part. But the drawing doesn’t mark the NC, NO nor COM pins on the relays. I can figure that out by theory of operation, but not the drawing.Basically you turn the switch on before going to 4WD and 4LO and tricks the ECU into thinking the ADD for the front differential is locked in, but it isn't
I suggest driving some competing trucks.I have absolutely no problems on the highway
I've done longer trips with the automatic and it didn't shift in and out any different than our old Camry.
AT, high altitude. Truck is dangerously gutless on Colorado/Wyoming interstate.MT or AT?
AT gonna suck no matter what. My arsesense had enough cents to not buy an AT
My MPG didn't change much, if it did because I drive a bit more spirited and the 4.88s, yes. That said, it's a truck. It's 3.5L. What do you expect? Mine goes faster than I need and I didn't buy it for MPGs.
