What he also knows is internal o rings didn't get nicked and no rtv broke free and got into the oil galley.
Agree no need for another for a few OCI.
What proof do you have or is this your opinion?The blue Subaru OEM filters are garbage.
Yeah I'm exaggerating when I say "garbage". I just don't like cardboard end caps so call it what you want. It's not as well made as the black Japanese Subaru filter that came on the new car. I believe that is an established fact. So maybe some opinion thrown in with some fact?What proof do you have or is this your opinion?
You mean you kept the same filter on the car for 170,000 miles?Probably around 170,000 of the over 190,000 miles on my Forester XT were using the OEM Honeywell filter. Never once had an issue with that filter.
Edited for grammars.You mean you kept the same filter on the car for 170,000 miles?![]()
Pretty sure this engine does not have an oil cooler. Where else would copper come from on break in?It would be impossible not to have high silicon when the engine halves and other parts are put together with RTV, 100% normal for a Subaru.
Copper is from the oil cooler. The rest are fine for 1K on a new engine.
It's a normal part of break-in wear metals.Pretty sure this engine does not have an oil cooler. Where else would copper come from on break in?
Copper is widely used due to its high ductility and thermal conductivity. It is mainly utilized in bushings and bearings such as: crankshaft journal bearings, connecting rod bearings, camshaft bushings, piston wrist pin bushings, thrust washers, and even heat exchangers (oil coolers).
So this is most likely wrist pin bushing copper? I understand copper is a normally elevated wear in metal but curious on non oil cooled fb20 where it is coming from? Only copper source that comes to mind is wrist pin bushings. Copper layer of rod bearings isn't yet exposed, I dont believe there is copper in the wear surfaces of the heads anywhere?
It's not even an EJ engine. FA/FBs have not had HG issues.Oh no! Maybe it's the infamous Subaru head gasket failure!![]()
Just clowning.
I think you'll be all right. It's probably from sealer residue in a new engine.
How bout the paper, rag, and fiberglass filter paper part ? How do you feel about that?Yeah I'm exaggerating when I say "garbage". I just don't like cardboard end caps so call it what you want. ...
Check this out:
I see you are one of the card board haters. You don't see very many failures with those like separated end caps and torn media like the ones you probably desire.
Completely agree, and I don't know what the issue is with Subaru mounts vs. others, but even when using German Torque (guten-tightenIf you have ever had a WIX or Pur-Oil-leaker on an EJ engine you would cherish that leak-proof P gasket.
I will note that ADBV may not matter much on the FB series as they appear to empty the filter after a hour sit.
- Ken
