2020 Frontier - Tires again
A Frontier calls for LTs?
No. And the OP is not using LT rated tires. He's just saying his warranty was denied because "light trucks" are not covered. His truck is not a "light truck" though... the dealer or tire manufacturer is simply trying to rip him off.
As title states, it tire buying again. 2020 Frontier I purchased tires from Mavis last Sept called GreenMax 55k miles tires that are Mavis Tires. Come to find out no warranty if on LT. I now have 20k on them.
Let me clarify, I tried to get warranty and got the run around so I looked up warranty and it states right in warranty that Light Trucks are no warranty for tread life. I checked most other manufactures and same thing as wear increases with weight is all I can come up with. Also if you do delivery, commercial or rideshare no warranty for treadwear.
I just ordered Firestone LE3 for less than any other major brand. Got 4 tires for 630 if I am not mistaken, so it was a 100.00 cheaper from Walmart.com and will take a week to come in. I will get mounted and balance from some one else than Walmart. Let's hope I get longer than 10 months out of a set of tires.
Joys of 60% city and 40% highway
2020 Frontier
80100 miles
Don't go to Mavis tire for anything if they don't have your tire in stock they will charge you to get them?? The last time I went there which was the last time I will ever go there. I'm waiting for two tires and they tried selling me struts that had no more than 20,000 mi on them
They are thieving bastards
Another thought... the company I work for has probably the largest fleets of Frontiers in the country. I would say they are not particularly attentively maintained and are certainly not driven gently. Most deliveries are similar to how DoorDash would be - small items, around town, etc. Occasionally large/heavy items like an engine or transmission or 55 gallon drum of oil. Typically it's the cheapest possible tire and mostly not rotated on time... they rotate when you drive, yaknow? And they always last more than 20k miles!
