Do you know where I can find the specs on the OEM filter? For example: What percentage of filtering at 20 or 30 microns?It’s actually closer to get the TG7317. The amount of filter media is closer to the Honda filter
Thanks
How about the CarQuest Premium Oil Filter 84356?It’s actually closer to get the TG7317. The amount of filter media is closer to the Honda filter
All we have is anecdotes. Never experienced the melting issue in the past either. Did experience distorted and leaking flat gaskets here and there over half a century. Professional (ret.) here so proper install of course.Those are certainly anecdotes. Otoh, over many years I've used filters of different brands with standard design nitrile sealing gasket on many Hondas, Nissan and Toyota. Installed as best practice recommended, and never had any issue, let alone melting gasket.
As I've mentioned in the past, only issue I've had was with dealer installed Toyota Denso OEM with p-type gasket. It leaked, suspect it was over tightened. Dealer replaced foc. No experience with Subaru, other than seeing the ring of fire location on some, so can't speak to them. As mentioned, in my experience with topic Honda/Acura, standard gasket type work fine.
Posted in another thread August '23Where are the pics? I do not see them.
In this case, correct. I'd say since mine specifically with Honda/Acura, imo more relevant/applicable to topic vehicle.All we have is anecdotes....
As it's OEM, unlikely to find any efficiency info from Honda. For OEMs, generally efficiency proprietary. In 2011 Amsoil sponsored an ISO standard efficiency test of several OEMs that showed the A02 to be ~67% @20umDo you know where I can find the specs on the OEM filter?
I've used M1, Fram XG and Honda. I run them for 2 (or even 3) 5K OCIs.
Good luck last I saw it was %50 or something like most oem filtersDo you know where I can find the specs on the OEM filter? For example: What percentage of filtering at 20 or 30 microns?
Thanks
This one is most interesting to me. I looked at it and the gasket is made almost exactly like the OEM and this one has synthetic internals vs just paper. Price is great. How long you been using this? Ever had any problems with it? I am a bit concerned that the synthetic internal material will change the pressures and oil flow thru the filter (more restrictive). Any thoughts on this would be helpful. My understanding is the OEM filter will filter out approximately at 67% greater than 30 microns. So, I am seeking something a bit better than this but that will NOT change or affect internal pressures of oil flow in filter and engine.Carquest premium 84356. premium guard made. heavy duty construction silicone gasket/adbv for $7 before discount codes.
your engine will not feel a difference in dp/flow. the carquest premium filters are the only filters i buy now other than fram endurances.This one is most interesting to me. I looked at it and the gasket is made almost exactly like the OEM and this one has synthetic internals vs just paper. Price is great. How long you been using this? Ever had any problems with it? I am a bit concerned that the synthetic internal material will change the pressures and oil flow thru the filter (more restrictive). Any thoughts on this would be helpful. My understanding is the OEM filter will filter out approximately at 67% greater than 30 microns. So, I am seeking something a bit better than this but that will NOT change or affect internal pressures of oil flow in filter and engine.
Thanks
Nice. Thanks a lot for sharing. It is challenging to sift thru all the marketing BS these days in the filter and oil products...your engine will not feel a difference in dp/flow. the carquest premium filters are the only filters i buy now other than fram endurances.
You can't tell how any oil filter will flow just by looking at it - it would have to be flow tested to know for sure how the dP vs flow behaves. Pretty much every oil filter will flow fine an the engine won't care because they all will only have a few PSI of flow dP difference at high engine RPM (high oil flow rate) when the oil is hot.I am a bit concerned that the synthetic internal material will change the pressures and oil flow thru the filter (more restrictive).
I could not find any specs on the OE to compare with the others so why I am reaching out to the community for knowledge on this....Synthetic blended filter media can flow better than pure cellulose media, and full synthetic media can flow better than all of them. But flow vs dP performance is also a function of total media area. Worrying about oil filter "flow" is a waste of time unless you're in a race car at redline most of the time.
Ahh, the sentient engine!your engine will not feel a difference in dp/flow. the carquest premium filters are the only filters i buy now other than fram endurances.
i don’t know if you see all the filters i cut open, but as i said carquest premiums or endurances are all i buy now due to tearing issues. my personal vehicles all run on OG wire backed titanium’s.Ahh, the sentient engine!
It will feel pain when you tear a pleat or two (not uncommon) and you are bypassing a good percent of the pumped oil through a rip. This happened in our fleet a couple of times across winter. One bitten, twice shy.
I think there is a reason many guys critical about filter performance chose a quality filter with wire or mesh backed synthetic media
that evidences excellent dirt capacity along with high efficiency and "flow" capability.
I have bumped into a few "filter related" issue over the past two decades. Something you shouldn't have to worry about - and haven't given it much thought on the past - then it rears its head in odd ways and starts damaging your engine. Frustrating and maddening.
What are tearing issues?i don’t know if you see all the filters i cut open, but as i said carquest premiums or endurances are all i buy now due to tearing issues. my personal vehicles all run on OG wire backed titanium’s.
M+H built Mobil 1 filters are tearing in service at the moment, new style fram ultra/titanium’s are tearing. at the moment, i only trust wire backed filters from the US brands and then any of the premium guard filters.What are tearing issues?
Filter paper ripping open usually near where it is glued at the metal end caps.What are tearing issues?
