A bit of an update on my UOA dataset. Based on the post in the main PCMO sub-forum with a discussion of LSJR's lastest YouTube video regarding M1 0W40 oils and statistics of what is meaningful or not in a UOA, here are some quick stats on my dataset as I probably have one of the more robust ones here in the BITOGosphere (21 to-date).
https://bobistheoilguy.com/forums/threads/lake-speed-jr-reviews-several-0w-40s.385283/
I just calc'd stadard deviation of each variable and looked at anything above/below as being worth a note/look.
A few notes:
I just used my best judgement on what to exclude - the orange highlighted cells. These are when the engine was new and the intial drop of the various analytes hadn't been "flushed out" yet, roughly 20K miles but you can see some had dropped to close to average levels after the first change so I kept those in. I didn't include the first change in the viscosity analysis b/c it's a 30 grade best I can tell from the factory. I'm primarly looking at values higher than one standard deviation from the average as something important (red highlight/"bad") but for example cSt 100 being high is better than low so those get a green highlight/"good". Flashpoint being lower than average is "bad" so gets a red lightlight. TBN is related to OCI so left it out. Finally, the HPL oils pose a bit of an issue as they VOA I have done shows ~10ppm Si so I backed out 8 from each (except the 5/8 sample as this was a custom blend David was working on with me and the it only had 8ppm so just backed out 4..again, judgement call). I know some folks are seeing a bit of Al in their VOAs but mine had none - I *think* these are only in the no-VII VOAs?
@OVERKILL showed 3 I believe in his Supercar 5W40 which is the same as my Euro but I just left that alone, they seem reasonable to me as-is but maybe a few ppm could come out. Won't change anything.
This is about what I would have flagged without the quick stat analysis and jives with the notes of what would be expected with those issues/repairs/etc. To the question about LSJR being concnered with a slight up-tick in wear metals switch oils/two changes to flush the previous oil out, yeah, 4 ppm variance without a lot of data isn't valuable at all/can't say much to compare two oils...it's just dataset noise. With that said, few will ever have 30 UOAs on a vehicle (30 being a good number you can find for a sample population to use for this kind of analysis) so at some point, you just look at what you have and make a call.
