- Joined
- Sep 26, 2010
- Messages
- 9,807
Gang,
Here is the 4th UOA using MS5K and it is the longest run thus far. The question comes at this point--do I push a bit further or call it a day? I have not yet decided, but a 1.4TBN is likely right at the limit and my driving pattern has changed somewhat, so the oil has more sump time, but the oil has still held up very well (even as a 5W-20
). Decisions, decisions...
I will again echo the fact that in a normal engine with no special characteristics and unless one is willing to run synthetic more than 20K (to recover the cost), then you are wasting your money running a synthetic oil. I will also stand behind 5W-20 in that it is much more robust than people are willing to concede--I am nearing 100K on my truck and it is running just as well as it ever did and the wear metals are trending very well.
The numbers speak for themselves...
Blackstone Comments:
This is the longest oil run for your F150 so far, and the engine barely even noticed. You can see that iron has slowly increased over time, which is perfectly normal. Iron is the one metal that tracks most obviously with miles on the oil, so it should be reading higher at 10,000 miles than it was at 7500 miles. These metals are nicely balanced, and we found no contamination at all in the oil. The TAN read 3.0, which is not too acidic, and the TBN read 1.4.
Code:
Year: 2010 Make: Ford Model: F-150 FX4
Engine: 5.4L FFV Transmission: 6R80 Axle: 9.75 Ford ELD (3.73)
CONVENTIONAL > SYNTHETIC
Date: 04/13 11/12 08/12 06/12 | 05/12 02/12 11/11 09/11 07/11 06/11 05/11 03/11 02/11 01/11 10/10 9/10
Oil Brand/Type: MS5K MS5K MS5K MS5K | PU PU PU PU PU PU PU PU PU PU PU MC
Oil Viscosity: 5W-20 5W-20 5W-20 5W-20 | 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20 5W-20
API Service: SN SN SN SN | SM{A} SM SM SM SM SM SM SM SM SM SM SM
Oil Filter: MC MC MC MC | MC MC MC MC MC MC MC MC MC MC MC MC
Air Filter: NG NG NG NG | NG NG{B} MC MC MC MC{B} MC MC MC MC MC MC
Lab: BLKST BLKST BLKST BLKST | BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST BLKST
Truck Mileage: 99,231 89,211 80,927 74,447 | 69,305 62,055 54,575 47,075 39,770 32,280 27,100 21,600 16,600 10,600 4,500 991
Oil Mileage: 10,020 8,285 6,480 5,142 | 7,250 7,480 7,500 7,305 7,490 5,180 5,500 5,000 6,000 6,100 3,509 991
Aluminum: 3 3 2 2 | 3 3 5 3 2 2 3 3 6 3 3 3
Chromium 1 1 1 1 | 1 1 1 1 1 1 1 1 1 1 1 0
Iron: 16 12 10 10 | 11 8 13 8 9 7 9 10 18 13 10 18
Copper: 2 2 2 1 | 2 1 2 2 2 2 3 4 4 5 9 41
Lead: 0 0 0 1 | 0 0 0 0 0 0 0 0 0 0 0 2
Tin: 2 1 4 0 | 0 0 1 0 0 0 0 0 0 0 0 0
Molybdenum: 3 6 3 11 | 48 56 46 47 58 55 54 45 47 52 48 42
Nickel: 1 1 1 0 | 0 1 0 0 0 0 1 0 0 0 0 0
Manganese: 1 1 1 0 | 0 0 1 0 0 0 0 1 1 1 2 10
Silver: 0 0 0 0 | 0 0 0 0 0 0 0 0 0 0 0 0
Titanium: 34 32 30 24 | 2 0 0 0 0 0 0 1 0 0 0 0
Potassium: 0 4 4 2 | 6 0 6 5 1 0 2 3 4 2 3 14
Boron: 3 4 7 9 | 91 249 156 144 156 233 244 230 249 278 258 272
Silicon: 12 12 11 12 | 13 11 16 19 21 19 19 17 16 29 45 111
Sodium: 369 362 374 284 | 4 4 7 5 3 3 3 4 4 4 4 9
Calcium: 2200 2276 1954 2195 | 2647 3168 3003 3053 2941 2900 2814 2613 2740 2911 2706 2203
Magnesium: 19 19 12 15 | 17 15 17 17 16 12 12 11 12 12 12 14
Phosphorus: 706 735 624 655 | 688 728 671 668 710 713 676 608 629 691 643 773
Zinc: 832 797 738 765 | 762 820 724 743 861 834 813 675 718 774 752 835
Barium: 0 0 0 0 | 0 0 0 0 0 0 0 0 0 0 1 16
cSt Visc. @ 100°C (UOA) 7.69 7.96 8.05 7.73 | 8.34 8.25 7.93 7.80 8.45 8.04 8.14 8.21 8.12 7.72 7.94 7.09
VOA MS5K cSt Visc. @ 100°C 7.48 7.48 7.48 7.48 | --- --- --- --- --- --- --- --- --- --- --- ---
MOBIL cSt Visc. @ 100°C 8.4 8.4 8.4 8.4 | --- --- --- --- --- --- --- --- --- --- --- ---
VOA PU cSt Visc. @ 100°C --- --- --- --- | 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 7.62 ---
SOPUS cSt Visc. @ 100°C --- --- --- --- | 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 8.41 ---
SUS Viscosity @ 210°F 51.4 52.3 52.6 51.5 | 53.5 53.2 52.2 51.7 53.9 52.5 52.9 53.1 52.8 51.5 52.2 49.4
Flashpoint in °F 395 510 390 {C} | 415 405 420 415 410 425 405 390 410 390 400 390
MOBIL Flashpoint in °F 446 446 446 446 | --- --- --- --- --- --- --- --- --- --- --- ---
SOPUS Flashpoint in °F --- --- --- --- | 435 435 435 435 435 435 435 435 435 435 435 ---
Fuel %
Antifreeze % 0.0 0.0 0.0 0.0 | 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Water % 0.0 0.2
Insolubles % 0.4 0.4 0.2 0.1 | 0.3 0.3 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.1
TBN 1.4 2.7 2.6 3.7 | --- --- --- 5.4 --- --- 5.6 4.8 5.3 9.4 7.5 ---
TAN 3.0 2.6 4.3 --- | --- --- --- --- --- --- --- --- --- --- --- ---
NOTES:
Acronyms:
BLKST=Blackstone | MS5K=Mobil | PU=Pennzoil
{A} Possibly SN in SM bottle; note drop in Calcium
{B} Air filter change; MC=Motorcraft, NG=Napa Gold
{C} Blackstone spilled sample; not enough to test FP and Fuel%
Code:
Fuel %
Water % 0.0 0.2
NOTES:
Acronyms:
