Why push it? Because there is clearly life left.
If he had run a UOA at 5k miles, some folks would say to "be safe" and OCI at 3k miles, because it's "cheap insurance".
If he had run a UOA at 7.5k miles, some folks would say to OCI at 5k miles, because he's got "safety margin" at the shorter OCI.
When he runs 10k miles on the OCI, and there is life left, why should he ignore the data he paid for? Because "
why push it?", right?
And I call into question how you prescribe this statement:
Originally Posted By: Artem
going longer wouldn't do you (or your engine any good)
SAE study data, and UOA macro data, shows that wear rates continue to DROP out towards 15k miles. How is that "not good" for an engine? Extending the OCI out is good for his wallet, and his engine.
Extending the OCI should NOT be done blindly; but he's not blind. This isn't a sinle UOA; this is one in a long series that shows the engine is in fine health. There is excellent contanmination control, and very low wear rates. The TBN has dropped, as do all lubes, but the TAN is very much in control and not at a condemnation point. I never encourage extended OCIs on a whim, but this isn't whimsical; it's methodical. Short of yanking the engine out and doing a full-blown teardown, just what more could you possibly want?
Other than your gut feeling, just what is it that points towards a manadatory OCI at 10k miles? Please be
specific and describe in detail the tell-tale signs you see that show imminent demise of the engine. If he had posted these UOA results, all in series, but never put an OCI mileage on them, just what would be your first clue that this fluid has been over-run? In fact, if he had posted the results, and not put the mileage or lube brand in there, just what would you point to? Don't forget; this Mobil dino lube is doing EVERYTHING that the expensive PU was doing, for far less cost!
You'd just be doing it to prove that it can be done.
Yes - that's exactly right. That's why Henry pushed the low-cost high-volume model T; it's why Bell called out to Watson; it's why Neil walked on the moon. Sure, those are extreme examples and 2010_FX4's little garage experiment isn't world changing; I get that. But your comment seems to be predicated on mediocrity and waste being desirable.
Why do UOAs at all, if all one is going to do it pick an arbitrary OCI from ones posterior? Why pay for knowledge and then ignore it? Why let the data talk, and then not listen to it?
He's not so much "pushing" the fluid as much as most other folks are wasting it. He's using a dedicated, thoughtful, consistent, analytical approach where most folks simply wing it ...
