maybe i should stop at autozone today and see what they have as far as a replacement pcv valve
Couldn't hurt but I would still double check all connections/lines. Inspect for cracks, hose slightly loose etc.
I agree with this.I wouldn't OCD over it...likely not worth the expense for this car.
Yeah I know I'm a bit ocd with this car ha. If Rislone won't help with it then I'll just let it be. Just changed the oil last week. Consumption is right where it should be!I agree with this.
Rislone won't hurt but not sure it would do much for your start up puff either. I would definitely keep using the Valvoline Restore and Protect though! Good to hear consumption is still low![]()
a blown head gasket and there were no symptoms before? extremely unlikely unless someone before you overheated the car a few times.Most of what I'm reading says no on the sealant too. I really dont have the extra 2500 laying around right now and not sure if this is a job I could do myself...
