Piston soak is a DIY project, I’m not sure any mechanic would agree to doing it, I certainly wouldn’t if I was professionally wrenching on cars.
There are some TSB's for the procedure, but I agree....most mechanics will not be interested in doing it.Piston soak is a DIY project, I’m not sure any mechanic would agree to doing it, I certainly wouldn’t if I was professionally wrenching on cars.
The piston design is perfectly fine, it has 8 holes into the skirt and 4 slots to the gudgeon pin boss area, the issue is the race engine/high revving motorcycle engine oil control rings toyota put in there. While they are fantastic when new, they require removal and replacement or cleanup at regular intervals.that wouldn't really help much, as the piston design is the issue, along with the oil control rings (in the piston rings)
@Elkins45 What is the current oil consumption now? Zero? What is the current odometer?The Berryman’s soak saved my 2009 Scion with the same engine. It was burning a quart at every fill up when I bought it and two piston soaks stopped the oil burning completely. Once you unclog the oil drain holes it’s like a new engine.
I did look into getting something that would do that for me but Ive seen so many other people on here with success without that so I passed on it. But im sure it would make a difference.The one thing I notice in the TSB is that it recommends pressurizing each cylinder at TDC, I assume to force the solvent down to all the rings. Makes sense.
