Emanuel
Originally Posted By: Ducked
In Venezuela you could probably run a straight weight oil which MIGHT cut consumption a bit and would reduce the chance of ring sticking, IF that is likely to be an issue.
I'm gonna do one last oil change with the HDEO 15w40 because I already bought the oil and then I a going to use 20w50 again, the coldest starting temp the engine sees is 68 °F and the user manual says that you can use 20w50.
