2008 VW Jetta 2.5 oil change help…
FL, USA
This is my brothers new daily. I’ll be helping with the oil changes. I see it has an odd oil filter canister design. I’m wondering if anyone who owns a 2.5 can confirm what size filter wrench cap to get. I only want to purchase one, the right size (vs. getting a set).
Oil will be 502.00 spec, all 6.3 quarts. Yikes!
Thanks in advance.
dishdude
$100 Site Donor 2023
Phoenix
There's some weird little tool to drain the oil from the canister, but you don't need it...it'll just make a mess like a spin on filter. I don't trust that little valve anyway.
TX
I just use an oil filter wrench to "break" before hand spinning it off. I just hand tighten.
CA
Only if you're an ape with no fine muscle control. It's fine. It's not on there very tight; you might not even need the wrench.
It might work if you wrap a few towels around the housing, but I don't know if everyone is careful to use that method.
TX
It works fine without towels. I've used it on a 3008 Rabbit since 2008. 140K miles. Original oil filter housing. OMG!
