So I started doing some diagnosis today. Two things have cropped up that are 'new'. That is the fuel gauge not working, and the fans on full by default when the engine is running.
As always, when presented by a problem I start gathering information. What are the chances of these two issues starting simultaneously and being totally unrelated?
I started looking at wiring diagrams and come across 'Sender Earth 410'. This is a clean earth from the instrument cluster that goes to the fuel level sender, brake fluid level switch, coolant level switch, screen wash level switch and ambient air temperature sensor. And a little googling shows a few people who had issues with the fans running on full when their ambient air temperature sensor failed.
So I went out to the van armed with my trusty £7.99 multimeter from Lidl. First thing to check was which side was the interior loom and which side was the fuel tank loom. I checked for resistance between the fuel level sender pins and found the female side to have 167ohms or so. Which, is what I'd expect for the fuel level in the tank.
I then checked from the battery negative terminal to the two sender pins on the male side of the plug looking for an earth, but both pins were open circuit.
So, I put the plug together, popped the test lead into the current measurement side of the tester, and fed the battery negative into the appropriate terminal on the plug. And BOOM! Working fuel gauge and no fans...
So, at this moment in time I'm assuming an internal failure in the cluster itself. The ambient air temperature sensor is in the headlight loom that I had out during the last lot of work I did. Maybe one the plugs got wet and shorted out the cluster? Question is, if this will be a DIY fix or if I'll have to send it off to be repaired. We shall see!
The oil pressure light is now pretty repeatable and consistent. Once the oil temp is above 70°c or so, I can pretty much make it come on and off on command. I'm pulling the sump off this weekend to take a look and find out what's going on. The engine still sounds and runs perfect, so while it's pressure is low, it must be borderline. Either the oil pump is tired or something is blocking the pickup.
Today I've spent a small fortune. I've ordered polyurethane bushes all round, new shocks, springs, mounts, drop links, ball joints, tie rods and a new oil pump. I start a new job in a month so don't have much time to get it all done before I'll need the Volvo on a daily basis as my company car will be going back. So there should be a decent amount of updates in the coming weeks!
