My second UOA!
2001 Mitsubishi Eclipse
2.4L I4 - Gasoline
Oil Interval - 3521
Make-up Oil - none
Mileage - 45163
Air Filter - Fram - used @ 7000 miles
Oil Filter - Wix
First number is my previous sample - second is my new sample
Al - 2 _____ 2
Ch - 1 _____ 0
Fe - 3 _____ 3
Cu - 2 _____2
Pb - 0_____ 0
Tin - 1 _____ 0
Moly - 73 _____21
Ni - 0 _____0
Mg - 0_____ 0
Ag - 0 _____0
Ti - 0 _____ 0
Potassium - 0 _____ 0
Boron - 113 _____ 13
Si - 12 _____9
Sodium - 2 _____2
Ca - 2165 _____1955
Mg - 5 _____63
Ph - 770 _____752
Zc - 1017 _____944
Ba - 0_____ 0
Sus Visc - 56.9_____59.5
Flash - 410_____410
Fuel - Antifreeze - 0_____0
Water - 0_____0
Insol - 0.3_____.04
Comments - Paul, we found very good wear in the first sample from your Mitsubishi engine and it actually improved in this second sample. This is especially good considering the oil was run a little longer. These wear accumulations look perfect and we see nothing here that would show a problem. The oil was normal in viscosity and the TBN read 4.1. This is a strong reading and shows the oil still has plenty of life left. 1.0 or less is a problem. Insolubles were low at 0.4% showing good oil filtration. Everything looks good here. Suggest going to 6000 miles on the next oil.
Mine - As noted this is Havoline Full-Syn. It seems to be doing quite well, and I think I will bump up to a 5000 mile interval. Thank you Advance Auto for pricing this stuff so aggressvely and please do it again!
edit - I am single-handedly improving the universal average for this engine!
[ April 15, 2004, 10:16 PM: Message edited by: tec97 ]
2.4L I4 - Gasoline
Oil Interval - 3521
Make-up Oil - none
Mileage - 45163
Oil Filter - Wix
Al - 2 _____ 2
Ch - 1 _____ 0
Fe - 3 _____ 3
Cu - 2 _____2
Pb - 0_____ 0
Tin - 1 _____ 0
Moly - 73 _____21
Ni - 0 _____0
Mg - 0_____ 0
Ag - 0 _____0
Ti - 0 _____ 0
Si - 12 _____9
Sodium - 2 _____2
Ca - 2165 _____1955
Mg - 5 _____63
Ph - 770 _____752
Zc - 1017 _____944
Ba - 0_____ 0
Flash - 410_____410
Water - 0_____0
Insol - 0.3_____.04
