My 2000 CRV, A/T 4WD EX, has recently started acting up when upshifting from 2-3 sometimes. It usually happens when accelerating relatively hard and allowing the RPMs to exceed 3000.
For example, the tach will read 3500 and the transmission will begin to shift from 2nd to 3rd. The rpms will then jump to 3800, float there for a second, and then shift up into 3rd gear. I understand this is called a "flare."
It does not do this all the time, but I had never noticed it before. Shifts were always nice and crisp. Other than this issue the transmission doesn't do anything out of the ordinary.
Fluid is clean, I do a drain/fill around every 10k. I also have a Magnefine filter inline with the cooling circuit. The last one was on there about 30k. I inspected it when I replaced it and it was quite clean. The transmission does not appear to be shedding much.
A little searching and perusing the FSM leads me to suspect the following things that I could inspect/change/service:
- Throttle cable
- TPS
- A/T temp sensor
- Linear shift solenoid or gasket/filter
- A/B shift solenoid or gasket/filter
- A/B lockup solenoid or gasket/filter
The FSM troubleshooting guide also suggests this issue could be due to a worn clutch. If that's the case, then I'd be looking at a rebuild. I've dropped a handful of Honda and Toyota manual transmissions but never an A/T. Any reason this should be much harder? Would I have to get a new torque converter too?
I'd appreciate any input or suggestions.
- Throttle cable
- TPS
- A/T temp sensor
