Shift flare after fluid change
Wrote a little with a guy from Sonnax checking if they have valve body for my box. (If ever needed) They didnt. Only to first generation.
Anyway. He suspects my gearbox is toast because the fluid of the initial drain was really dark. Me... i dont think anyone can say that by looking at the colour of a fluid that have been in there probably 13 years and 240 000 km. Especially a gearbox with partial lockup that is designed to slip a little for more comfort....
He little bit lost my trust there.
I didn't see the fluid, but if it wasn't recogniseable on sight as ATF, my experience is the transmissions have issues over half the times.
This is how the fluid looked like. It wasnt any grit in it. I also took a magnet and fished around with it without finding anything that wanted to stuck on the magnet.
I dont think its something wrong with the gearbox. It shifted fine before I changed fluid.
  • Like
Reactions: D60
Wait, the guy that sells transmission rebuilding parts thinks you need a transmission rebuild? Look, Sonnax is great, and I’ve used their products for a lot of things. Excellent company based in Vermont.
But if all you know is hammers, everything looks like a nail to you.
The color of the fluid doesn’t mean your box is toast.
Many years ago I flushed the fluid on a Volvo 850, with an AW42 transmission. The car was new to me, and I had every record back to the bill of lading when it was taken off the boat from Sweden (military sale).
The fluid had never been changed. 140,000 miles. It came out jet black. I mean absolutely opaque black. Like used diesel engine oil.
That transmission shifted perfectly, smooth, and worked great for the rest of the cars life.
Haha yeah well 🤷
I didnt really listen to that actually. I know by my own experience that automatics usually have pretty dark fluid in them if they arent maintained regulary. And here in Sweden where manual car is the most common still, people listen to dealers saying its "a lifetime oil" in their auto gearbox so they never change it. And then I buy that car "full serviced at Volvo" and the gearbox runs with factory fluid in it. 🤷
However. Ravenol t-iv syntetic is on its way from Germany. A little bit higher viscosity, especially at 100⁰C. Hopefully that will help.
If the gearbox starts to behave before I get the package I can use it in a Saab 9-3 I have. So no harm done whatever happens.
So an update then...
I flushed 20 l of Ravenol T-IV yesterday. No improvement. It even became slightly worse.
So now I dont know what to do. It really feels like its an adaptationproblem or valvebody.
But the weird thing is that in sport mode or manual (Geartronic-mode) the shifts are firm and quick. But as soon as I go to D it starts to flare. Except when the transfluid is cold. It shifts fine even in drive.
So what can it possible be?
Internal leakage in the valvebody when warm or TCM-fault (not adapting) is my guesses.
However. I have booked the car for fault tracing at our local Volvo dealer. But its more then 2 weeks until they could take it in. I hope the clutches isnt gone by then.
There is only a screen inside these trannys. Have to take the trans out and into pieces to reach it. No pan. :/
  • Like
Reactions: D60
Okay so I think I have found the problem. This is the SLT solenoid in the valve body. Actual current is differing from asked current. Cannot see the pressures in Volvo Vida but I guess this shows pretty much the same. There is probably an internal leak in the valve body that showed up when I put fresh fluid inside it.
The other solenoids didnt differ anything with actual current and asked current.
Sometimes manufacturers don't have clean breakpoints when they make changes. I've seen it happen dozens of times during my career at GM. We would start a using a new part then the material dept would "find" a few racks of the old parts and the went on line to be used. You may have trans that actually needs the new trans fluid. Resetting adapts is not called for when doing a fluid change so you probably started the situation by doing that. That procedure is only for transmission replacement or major internal repairs. With that being said the car should eventually learn itself back to normal but could take 500+ miles in some cases. I would wait awhile then if it does not get better - go with the new style fluid.
Hi thanks for your reply.
I got the problems first time I changed the fluid with the new thinner oil and resetting of adaptions. After driving around a couple of weeks with that I changed fluid again to the old style 3309 oil. The symptoms are the same.
It seems like something is going on with the SLT solenoid as you can see in my comment here above.
I dont know if it is so good to drive around like this 500 miles more. Feels like I gonna burn the clutches. I tried to do an adaptionrun with the tranny in "learning mode" today. No difference at all. When its cold it shifts perfectly fine.
I just wanna let you guys know what the problem was. I changed the valvebody and now it shifts like new :) took me maybe a day in the garage. Not so difficult but had to lower the subframe to get the body out.
SLC1 solenoid was totally stuck. Maybe something more was wrong with it but I havent really investigated it.
Thank you for your replies!
Thanks for the follow up!
Great news. Well done!
Solid work. I was going to say that I’ve seen thicker fluids hold higher pressures and resolve or reduce shift flares, but I like your way better. You *fixed* it.
I believe I mentioned the “valve body surgery” performed on my wife’s 2002 Volvo V70XC in an earlier post. It was done at about 120,000 miles, and the car now has 306,000 miles on it.
Still shifting perfectly.
I am optimistic that you have genuinely fixed your car.
I’m pleased that you shared the outcome with us.
Cheers!
