water contamination isn’t really a problem. breakdown of corrosion inhibitors is more serious, sometimes brake fluid turns green from all the copper floating around
Of the small percentage (2%) of the crashes in which the critical reason was assigned to the vehicle, the tire problem accounted for about 35 percent (±11.4%) of the crashes. Brake related problems as critical reasons accounted for about 22 percent (±15.4%) of such crashes.
Easiest thing is to just drain or siphon out the reservoir, refill with DOT4 (less hygrospcopic, but DOT 3 can work). Drive it and it will mix. Repeat annually.
You can introduce air very easily via the screws if you are not careful; this is so much simpler and highly effective.
What I read is that DOT 4 is less hygroscopic, but when it does absorb moisture it's boiling resistance drop rate is MUCH faster than DOT 3, so there can be tradeoffs. StopTech and aa1 articles support this theory.DOT 4 is more hygroscopic than DOT 3 but its boiling point is higher, that's why some manufacturers used it.
They don't use brake fluid. Why not say the same with oil? No need to change the oil just because you don't change gear oil. See what happens when you run oil for 100k....I use gears more than brakes and don't have to replace them or fluid during the 100K that I run most vehicles.
That has always been my understanding, siphoning fluid out of the master cylinder and replacing with fresh fluid doesn’t really accomplish anything. It will never get down to the calipers. The only way to get the old fluid out is to open the bleeders and flush out the old with new.What basis do you have to say this is “highly effective”? I find it dubious that this does anything at all, particularly to get the damp, nasty fluid in the caliper (which holds a lot). And, it will not get that nasty fluid out; even if some level of moisture is redistributed/scavenged somehow (again dubious because of the small tubing and long, tortuous path), it won’t get the degraded fluid out of the calipers.
Fresh DOT 4 has a higher BP than DOT 3, so it is a higher performing fluid. However, since DOT 4 is more hydroscopic it's BP rating deteriorates quicker than DOT 3 and could get to a point where it's inferior to DOT 3 entirely. Should not be a problem for people who regular flush out the fluid, but since most people don't I would imagine DOT 3 is better for longevity.DOT 4 is more hygroscopic than DOT 3 but its boiling point is higher, that's why some manufacturers used it.
I wasn’t sure if I wanted to comment on this thread because I’m not an expert on brake fluid. But ever since vehicles started coming from the factory with DOT 3 and ABS brakes I have stopped changing brake fluid. From my experience it seems GM stopped recommending brake fluid changes around the mid 90’s. With the amount of complexity in an ABS module I’d rather follow the recommendation and leave well enough alone. I wouldn’t be a bit surprised if manufacturers start sealing off the master cylinder like they did with automatic transmissions.
Also, I remember reading a technical bulletin years ago from GM regarding their ACDelco Supreme II brake fluid. The article talked about how it wasn’t just any old DOT 3 fluid. It was designed by GM with extra corrosion inhibitors and some other properties that go above and beyond the DOT 3 specification.
The fluids mix fully. Brownian motion.
If you do the reservoir, you will drop a 4% (water content) system to 2%, do it twice and you drop to 1%. It's the same as a partial drain/fill in any system, really. It's tested, and works. You can demonstrate this yourself in your driveway with calcium hydride strips or test pens. Over time (and it's not a lot), the water content in the calipers will equal the content in the reservoir.
I keep all my vehicles to at least 200k miles. Haven’t changed brake fluid since the early 90’s. Haven’t had an ABS controller failure, nor had to replace any brake hoses or caliper pistons. I’ll keep doing what I’ve been doing.I think you're a little backwards in your logic. A thousand dollar ABS module having to be replaced is a lot more expensive than a master cylinder or caliper. I want fresh fluid with good anti-corrosion additives in my system at all times.
It's my understanding that there are very few ABS modules these days that require special bleeding procedures. Most of them simply require bleeding the calipers as normal.
Again, it all boils down to, how long are you keeping the car. If you're keeping it long term, maintain ALL of the fluids and systems. If you're dumping it after a few years, your call, whatever is in it will go that distance unless you're in a SEVERE service schedule (Racing, AutoX, Etc).
Why must you not accept other people’s point of view?so you have data you can provide where you took sequential samples, at the calipers, with no other removal of fluid besides the tiny droplet sample, and saw a real chemical basis of change?
I’ll reserve my doubts but entertain data.
To me, this sounds like draining your coolant bottle and topping it up, and assuming that the inhibitors will be replaced suitably over time... which forgets other reasons for exchange.
I also have seen gunk built up in brake fluid systems, and your process would not resolve that
The point on here is to look for data and discuss.Why must you not accept other people’s point of view?
FWIW Prestone says that a master cylinder turkey baster flush is an adequate flush. I also wouldn’t be a bit surprised if a majority of car dealerships consider a brake fluid flush to be nothing more than a turkey baster flush and call it a day.
Braking systems are much more durable than they were in the days of the 1960’-1970’s.
Bcs. in Europe they measure moisture level in break fluid during technical inspection required for registration. If you are at 3% and up, you are out.Amazingly Hyundai says 2 years in Europe...
I found the low viscosity fluid helps also at regular temperatures, if you have an fast cycling ESP unit. To the point you can't feel ABS in your brake pedal.
