Hello all,
Better late than never, I guess.
This was a test using two bottles of Auto-Rx, 1k clean and 2 1k rinse cycles, then back to normal services. Each of three cycles included an oil and filter change. Oil was Kendall GIII 5w-30.
1998 Honda Accord 4-cylinder, 5-speed manual
Clean phase 2 bottles
10/15/2007 start mileage 161,599
Compression 1=170, 2=175, 3=170 4=190
During this first 1k miles 2 quarts of makeup oil were added
1st Rinse phase
12/11/2007 162,514
Compression 1=195, 2=200, 3=195, 4=205
During this next 1k miles 1 quart of make up oil was added
2nd Rinse phase
01/10/2008 163,708 miles
Compression 1=205, 2=210, 3=215, 4=215
During this last rinse phase less than 1/2 quart of makeupo oil was added.
We started to test smog performance but this engine was in such good tune that the numbers showed no meaningful change. These injected Honda 4-cylinder engines do well in smog testing. The choice was my mistake.
What we found out is that the two bottle method really works. The increase in compression was phenomenal. The car feels like it has more performance and now starts quickly when it did not do before Auto-Rx. This car is driven hard and gas mileage was difficult to check because this young driver knows two speeds, full speed ahead and dead stop. We did check mileage but it was all over the place. One check before the testing was 20 mpg and several tests during the second rinse phase were in the 25 to 28mpg range but these numbers are worthless because of our friend's driving style.
The message I got from this test was that Auto-Rx can fix things inside an engine if these things are lubricated with engine oil.
Barker
1st Rinse phase
12/11/2007 162,514
2nd Rinse phase
Barker
