Very clear oil, aka miracle in my motor?
A few days ago, it was time for an OC in my old 1998 Fiat Marea 1,9 Turbodiesel. I grabbed a new oil filter, some Rimula R6 M oil I just bought in bulk...
Except that was not Rimula R6 in the tin (my bad, got caught by a coolant sensor issue and grabbed the wrong tin), it was a "Frankenbrew" made of some various oil (~50% Shell HX7 10W40 diesel and Elf 10W40 diesel, ~50% Elf 5W30 "gasoline" and Helix Ultra 5W40 "gasoline").
Oil pan was already filled with Frankenbrew, and since all these oils are API CF, I figured I'd wait and see what happens. Motor was running fine and smooth, I drove ~900 miles without troubles.
Today I checked and the oil is still very clear, almost impossible to see on the oil stick!
With this old tech motor oil is usually pitch black as soon as you change it and turn the motor on, I've never seen oil this clear, even when it was new!
EGR is disabled and the sensor I fixed corrected some minor spark advance issue I had when hot, but I don't think this is the cause for clearer oil.
Is it a sign the oil can't handle the soot? Should I change it right away?
(I usually use this "Frankenbrew" in some lawn mower of very old motor like Peugeot J7 diesel, good enough for it)
