Since Ford specifically stated why they started using 5W-20 I thought it would be obvious to all, but instead we have some sort of apparent cult that doesn't want to acknowledge it. If 5W-20 offered the same wear protection as 5w30 it could be used as an across the board replacement, but since it doesn't it's not. Some SHO owners have noticed that they're not on the 'use' list so they shouldn't use it either. Portions of the TSB below:
http://www.f150online.com/forums/showthread.php?s=&threadid=121018&highlight=ford+oil+article
Article No.02-1-9
ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5w30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY
Publication Date: JANUARY 14, 2002
ISSUE: Ford Motor Company now recommends SAE 5W-20 viscosity grade for servicing most gasoline and flexible fueled vehicles.
ACTION: All 2001 and 2002 vehicles where SAE 5W-20 is specified should be serviced at the recommended oil change intervals using SAE 5W-20. This oil is an improved formulation to improve fuel economy. Testing has validated this viscosity grade can be used in many previous model year vehicles. It is recommended ALL vehicles on the following Vehicle Application Listing be service with SAE 5W-20.
All 2001-2002 vehicles other than those listed in the "Exception 2001 Vehicles" or "Exception 2002 Vehicles" chart are being filled with SAE 5W-20 motor oil at the factory and should also be serviced with SAE 5W-20 oil.
NOTE: THE "EXCEPTION 2001-2002 VEHICLES" SHOULD BE SERVICED WITH SAE 5w30 MOTOR OIL.
Engine Vehicle
3.3L Villager
3.9L Lincoln LS
4.0L Ranger, Explorer/Mountaineer, Explorer Sport, and Explorer Sport Trac
Engine Vehicle
2.0L HP Zetec SVT Focus
3.3L Villager
NOTE: IF VEHICLE IS NOT LISTED IN THIS APPLICATION, SAE 5w30 OIL IS RECOMMENDED. REFER TO TSB 99-8-16.
