Less VI needed so has better resistance to viscosity changes.
I've found that in older vehicles, sometimes on a cold morning I would get a puff of blue smoke on startup using the recommended 5w30 oil. Simply by using 10w30 wt, it all but stopped smoking. As far as starting goes, I notice no difference, unless your battery is on it's way out. Where I live it can range between 0-32f all winter. I've found that as my vehicles age and get up in mileage, their oil consumption tends to go up.It may be from wear, or just drip leaks. Using a heavier grade of oil usually is cures the problem alot cheaper then a motor rebuild.,,
up there yeah id definitely use a thicker oil than a 20 or 30 grade but the hths doesnt really get better beyond a 15w-40 like chevron delo which is 4.2 and can actually get worse.It depends on where you live. I used 20-50 for years with no problems when living in Phoenix.
Is it only that, I though the datasheet said more than 3.7 or 3.8 whatever the minimum HTHS for it is, I assume the actual is higher.i know that gtx 20w-50 is 3.7-3.8 hths so pretty bad for its viscosity.
Is the difference due to being a SP rated PCMO vs a CK-4 rated HDEO?The idea is that the 10w-30 will be blended similarly and have less VII. That's likely not true. They can get away with using cheaper bases because of the narrower spread. I posted these two yesterday from Mobil, but they also appear to be germane to this discussion, so I will share them again:
5w-30 blended with Group II+ that meets DEXOS:
10w-30 HDEO blended entirely with Group II+:View attachment 68515
@wemay and I were just discussing ol' Merk a little while go. Him and Garak.Where is merkava, aka clyde, aka goldenrod when you need him?
Is there any chart showing 10w-30 PCMO formulation?
yeah it states that gtx 20w-50 is 3.7 but the spec for an sae 50 goes all the way down to 3.5 as the minimum but delo 400 sde is 4.2.Is it only that, I though the datasheet said more than 3.7 or 3.8 whatever the minimum HTHS for it is, I assume the actual is higher.
