My hunch is if you removed CAFE, EPA etc. and manufacture's desire to advertise best case MPG, recommended viscosities would be higher.
I think we need to revisit and learn what the W actually means.I use 0W20 in Acura in signature for Fall/Winter here in Pa... Switch back to 5W20 for other two seasons.
Maybe warranty claims had them rethink things......Here is the page from the 2022 Ford Explorer 3.3 liter twin Turbo with 18 psi boost and 9.5 compression ratio. It asks for 5w30 motor oil. I’m thinking Ford participated in moving oil viscosities downward for the past 20 years but now have gone back up for certain applications. Perhaps protection became more important than EPA gas mileage.
So it is as always and everywhere, everything has its advantages and disadvantages. I don't think you can make a universal statement. I have been driving exclusively the Mobil 1 FS 0W40 (since 2015, before that the new Life 0W40) in my suction pipe injector engine R18A2 for 406000 kilometres and have an absolutely clean run, very good oil analyses, even over longer periods of time, as well as a really clean engine, even at intervals of 20000 kilometres. The vehicle is completely maintained by Honda chequebook, except for the engine oil, Honda original liquids were used with me. My K20c1 from the Civic Type r is a direct injection engine that, like all of this kind, will tend to coking the valves sooner or later. This must be eliminated sooner or later. I think otherwise the wear protection with this oil is beyond doubt and absolutely great. Especially over the long service life in winter, this "non-PAO oil" is very good in considering the compatibility of the seals and materials over a particularly long service life, about 5 months. If interested, I will Continue to post trend analyses of oil.
I’ve been using 20 weight oils since day one until about 95k miles in my 2010 Ford Taurus SHO with the 3.5 eco boost. Ford recommended 5w20 in 2010 SHO’s and switched to 5w30 starting 2011 model year. I’ve always used 5w20 and 0w20 in my car because ford recommended 5w20 for my 2010 MY car.
Everything was great until about 95k miles. At around 95k miles, I started hearing some tapping noise from the engine with 0w20. The noise got louder as RPM went up. Almost sounded like rod knock. So when I reached 100k, I switched Valvoline EP 5w30 (one of the thicker 5w30 out there) and the tapping noise went away. The 0w20 I drained did not have any visible metal shavings, no grits, or anything abnormal. I’m assuming fuel dilution thinned the oil out too much and that’s what caused the tapping noise. Also the filter was clean when I opened it up. When I switched to 5w30, I also added some Liqui moly Mos2 which thickened up the oil even more, so the oil is probably a thin 40 weight oil.
I’m at 105k miles right now and there’s no more tapping noise and the engine runs good. I plan to use 5w30 or 40 weight from now on.
Nope. It’s a daily driver. And I know it isn’t sitting at the bottom of the oil pan.I doubt that can of glop thickened anything. It might be sitting at the bottom of your oil pan.
So she has demanded that you not be her servant...she refuses to let me do the maintenance for the stated reason that she didn’t marry me so I could be her personal servant.
Probably not the best idea they ever came up with though they have incentive to try and do so.Can 0W20 protect engine oil well in the long run? Especially for turbo vehicles with high performance? Can these motor oils offer permanent protection or only for a period of 300000 kilometres, for example.
I used it before and it turns th oil grey because, well, it is grey itself. Obviously it’s not sitting in the bottom of the oil pan.Nope. It’s a daily driver. And I know it isn’t sitting at the bottom of the oil pan.
I don’t know where people are getting this “liqui moly mos2 sits on the bottom of the oil pan and does not mix with oil” thing.
I’ve looked inside oil pans with borscope cameras just to see if the mos2 sits at the bottom of oils pans and I’ve found that it does not, as long as the car is a daily driver. Now if you let the car sit for too long, it probably will separate. Not really a concern to me.
Does it burn exhaust valves from valve lash not being adjusted on time? Or is there another reason, specific to the K20C1?My K20c1 from the Civic Type r is a direct injection engine that, like all of this kind, will tend to coking the valves sooner or later. This must be eliminated sooner or later.
