0w-20 direct injection oils
Greetings from Turkiye. Following oil analysis has become a hobby lately. However, I'm having some hesitations. My car is a Mitsubishi Eclipse Cross 1.5 Bezin with direct and port injection. The manual says max 2000 calcium. 6.7 tbn is required. Of course, Api sp and gf 6a... I can find these oils. However, it's hard to find pao-ester in Türkiye. Which one do you recommend? Amsoil signature 0w-20 (recently available on the Turkish market), Ravenol DFE 0w20, Shell Ect C6 0w20... I like these for now. I'm interested in other suggestions.
3 oil analysis here. Let's get started.
Welcome.
In your UOA, the Si looks high which could be why you're seeing elevated Fe/Al wear. Check your air filter for leaking.
All 3 of the oils you listed are very good. I'm actually surprised how good the Shell Ultra looks (on paper). The Amsoil SS 0w20 would be my choice of the 3 for no reason other than the data they provide off of their website.
The Amsoil 0w20 is a PAO/V based oil (maybe some III) with a very shear stable VM on par with the Euro oils. On the ROC they tested the shear stability of Amsoil SS 0w20 and it was excellent. SS also has very good solvency.
That's interesting that the owner's manual gives specific elemental analysis and TBN requirements. Does it give any kind of ACEA Sequence?
No, only; maximum 2000 calcium. GF/6A- API SP and TBN; 6.7
Welcome.
These analyses aren't mine. I got them from Russia and Poland. Shell looks good. The AI thinks it might contain PAO. But Shell hasn't announced it.
"The manual says max 2000 calcium. 6.7 tbn is required."
People in Türkiye must be very engine oil savvy or Mitsubishi is smoking something. :ROFLMAO:
That's not a very consumer friendly requirement! How do stores advertise their oil?
Also does the owner's manual list any temperature range and/or other viscosity grades? Is this a turbo?
" Kılavuzda max 2000 kalsiyum yazıyor. 6.7 tbn gerekiyor. "
Türkiye'deki insanlar motor yağı konusunda çok bilgili olmalılar yoksa Mitsubishi bir şeyler içiyor. :ROFLMAO:
Bu pek de tüketici dostu bir gereklilik değil! Mağazalar yağlarını nasıl tanıtıyor?
Ayrıca kullanım kılavuzunda herhangi bir sıcaklık aralığı ve/veya diğer viskozite dereceleri listeleniyor mu? Bu bir turbo mu?
I sent you the Japanese manual. It's from 2024.... The criteria I mentioned were written in the 2018 Turkish manual... Gf-6a didn't exist back then. Mitsubishi acted with foresight and added a Calcium criterion. So Mitsubishi didn't consume alcohol. They only considered the possibility of LSPI. The car is turbocharged.
are you really in Turkey? Test done in Moscow? WTH. русский мир
Yes, I live in Türkiye. These tests are not mine. I took them from oil-club.ru. I follow the active Eclipse Cross Russia group on Telegram. There are many helpful and knowledgeable people there. If you want to get tested in Türkiye, they may ask for 300-500 euros.:)
Yeah, I’m intrigued. That’s quite specific for an owners manual.
@Osman Any chance you can post a picture of the owners manual page that’s recommending <2,000ppm calcium?
[trange. USER=110945]@Osman[/USER] Any chance you can post a picture of the owners manual page that’s recommending <2,000ppm calcium?
You can see it online, I found a PDF. And yes it’s strange, also strange is that it gives a recommended API license.
I’d probably use an ACEA C3 oil.
Is high sulphur in the fuel a concern hence the min TBN requirements?
If so, does that mean shorter OCIs with C3?
Aptalca bir tanımlama!
Ortalama bir tüketici (%99,999) bunu nasıl anlayabilir? Birçoğunun kullanım kılavuzunu bile okumadığı düşünüldüğünde.
Frankly, people have subjective judgments like, "This oil is good, that oil is great." I completed my master's degree last year. That's why I do a lot of questioning and research. I asked myself, "What's calcium doing in oil?" Then I learned a lot. I became a member of Bobistheoilguy because it said calcium. :) Mitsubishi is an interesting company. You drive a car for 5 years, and in the 6th year you discover a feature of the car. Finally, I think Mitsubishi has its oils made by Total in Europe. I looked at the total invoice for 9000, but the package is standard.
I became a member because my owner's manual specified 0W-20 and I had never used anything less than a 30 grade. It was much simpler than dealing with calcium and TBN.
What is your owner's manual recommendation for oil change intervals? Or How often do you change the oil? What oil and/or viscosity grade does Mitsubishi specify for the same engine these days. I mean did they revise anything since 2018?
I believe there was a recommendation for higher viscosity oil in these engines. I visited a friend from when I worked at a mitsubishi dealership (he still does) and he mentioned this. Can you find anything in Turkiye about this?
I'm always in favour of increasing viscosity when possible, but if there's a recommendation to do so from either Mitsubishi or it's importer I'd take extra notice.
I have a GM 1.5 T-gdi in my suv crossover, and I use a 10w30 API SN with 2000 ppm calcium, PAO/ester and apparently no viscosity modifiers, and TBN of 7.9
The manual that's listed above doesn't specify 0W20, it clearly says choose the proper viscosity according to athmospheric conditions. You could run 20W-50 if you wished and over night temperatures allowed.
Still 0w20 base oil. Fuel economy. But some people use 0w30 or 5w30. If you drive 120 km/h, the rpm is at 2000. I watched a video where 0w16 Toyota oil was more gentle than 0w20 oil.
I change the oil myself. I change the oil every 7000 km.
